Here :
http://software.hexagonmi.com/public...18_R1/SP5/x64/
Release Notes - 2018 R1 SP5
• PCD-50401 - Fixed an issue where the Jump Hole functionality failed or caused scans to fail.
• PCD-126983 - Fixed an issue where PC-DMIS stopped working if you reset the execution list while a measurement routine was executing.
• PCD-134313 - Fixed an application error that occurred when QuickFeatures were selected in the Auto Feature dialog box.
• PCD-135742 - Fixed an issue where path lines for probe head rotations were not drawn for probe heads with a C-joint (heads with 6 axis).
• PCD-137806 - Eliminated a null pointer related to a commonly reported PCDMIS 2018 R1 issue where PC-DMIS stopped working.
• PCD-138302 - Fixed the issue of not being able to correctly group axis and True Position for FCF True position with multiple features selected.
• PCD-139668 - Fixed a crash that occurred when cast points were used in a loop.
• PCD-140115 - When a new patch scan is created, all points taken for previous patch scan are deleted so as to create patch scan at new location.
• PCD-140952 - Fixed an issue with the displayed datum bonus value when the datum was shifted to its limit.
• PCD-141291 - Corrected always outputting the min max values to the statistics file.
PCD-144198 - Restored functionality that existed prior to PC-DMIS 2017 R1 to display the probe at the correct location in the Graphic Display window when a MOVE command was edited.
• PCD-144358 - Thickness now works for Auto Cylinder and Auto Cone.
• PCD-145145 - Fixed an issue that was introduced in PC-DMIS 2017 R2. The selection and highlighting of CAD surfaces was not working as before.
PCD-145787 - Fixed an issue where the Illumination tab did not appear in the Probe Toolbox.
• PCD-146258 - Fixed potential 15-second delays or crashes when switching between cameras on a multiple uEye digital camera system.
• PCD-147300 - Prevented a crash from occurring when the Vision laser (FLS) gain in the Probe Toolbox was edited.
• PCD-147567 - Fixed I++ errors for Technology Server 1.x in the self-centering code.
• PCD-147569 - ToolName (the name of the tip in the I++ server) has never been composed correctly for the purpose of scrolling in the measurement routine in the Edit window when LOADTIP is done sometimes.
• PCD-147666 - PC-DMIS I++ server has fixed readouts for DEA machine interface for manual CMMs.
• PCD-148136 - Prevented a possible incorrect initialization of touch probes in combination with VisionBox.
• PCD-148439 - Fixed the error of incorrect reporting of legacy True Position.
• PCD-149206 - Fixed temperature compensation V1 for Manual mode (this applies to I++, Zeiss, and other third-party machine interfaces).
