I played with the scans a few years ago when I first started using the DEMON and gave up because I couldn't use them for feature contructions and other relationships (at least I think that's why I quit using them), and I was wondering how many of you actually use them regularly? If so, have improvements been made since 3.5mr2 ?
Scans
I dont know about versions prior to 3.7MR3, but I scan everything with my SP600. (Best of all I got it for $free$ from a sister plant that wasnt using it.)
I also dont like the limitations of what you can do with the data. So I figured out a way to have VB or Excel VBA create a mass set of unique Generic features for me but directly into the PCDMIS part program, the key is that the Expressions get set to each HIT values in the Scan. When its all said and done I can use scan data to construct anything I want from Points.Mr. Comment
SCIROCCO-NT 13-20-10
I only use them for strictly 2-D work since unless you are using SURFACE points with 3 (minimum) sample hits, you are only getting 2-D probe comp and taking 4 hits for each point takes WAY too long for a TP2. AND, since we got a 3-D laser camera, I don't need to do any surface work anyway.
EDIT: This is for scanning WITHOUT cad data, with cad data you do get 3-D comp based upon the cad nominal vector.Last edited by Matthew D. Hoedeman; 04-05-2007, 11:13 AM.sigpic
Well I honestly I cheated some.
First I created a Generic feature that was "formated the way I wanted it". Then I used the File->Export->Basic utility in PCDMIS to print me out the command structure Id need to use to create the Features.
I read through it and then created a loop in VB that basically just adds Generic Points into my part program for me. (See the attached Zip file)
With the Attached File you can copy and paste the code directly into the Excel VBA Editor and execute it from there.
This is the basic idea of what it does for you below.
One further note, if you execute the code in Excel to create these Generic Points, after it completes you need to execute the PCDMIS program to get the points to show up correctly on the screen, and depending on the PCDMIS version also in the edit window. Closing the Graphics window in PCDMIS also makes this code Execute much faster as well.
Code:$$ NO,My Scan to Get the Data SCN19 =FEAT/SCAN,LINEARCLOSE,SHOWHITS=NO,SHOWALLPARAMS=YES EXEC MODE=DEFINED, NOMS MODE=FIND NOMS,CLEARPLANE=NO,SINGLE POINT=NO,THICKNESS=0 FINDNOMS=2,SELECTEDONLY=YES,USEBESTFIT=NO,PROBECOMP=YES,AVOIDANCE MOVE=NO,DISTANCE=0,CAD Compensation=NO DIR1=NULLFILTER, HITTYPE=VECTOR INITVEC=0.2249571,0.9743687,0 DIRVEC=-0.9743688,0.2249568,0 CUTVEC=0,0,1 PLANEVEC=-0.9743688,0.2249568,0 POINT1=-86.614,38.324,-2 MEAS/SCAN BASICSCAN/LINE,SHOWHITS=NO,SHOWALLPARAMS=YES <-86.614,38.324,-2>,<-86.614,38.324,-2>,CutVec=0,0,1,DirVec=-0.9743687,0.2249571,0 InitVec=0.2249571,0.9743687,0,EndVec=0.2249571,0.9743687,0,THICKNESS=0 FILTER/NULLFILTER, EXEC MODE=DEFINED BOUNDARY/PLANE,<-86.614,38.324,-2>,PlaneVec=-0.9743687,0.2249568,0,Crossings=3 HITTYPE/VECTOR NOMS MODE=FINDNOMS,2 ENDSCAN ENDMEAS/ MOVE/POINT,NORMAL,<-88.092,42.317,232.299> RECALL/ALIGNMENT,INTERNAL,A10 PROGRAM/END $$ NO,My Scan Data Ripped into Generic Points so that I can use it anywhere else. SCN19_PNT1 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<SCN19.HIT[1].TX,SCN19.HIT[1].TY,SCN19.HIT[1].TZ>,$ MEAS/XYZ,<SCN19.HIT[1].X,SCN19.HIT[1].Y,SCN19.HIT[1].Z>,$ NOM/IJK,<SCN19.HIT[1].TI,SCN19.HIT[1].TJ,SCN19.HIT[1].TK>,$ MEAS/IJK,<SCN19.HIT[1].I,SCN19.HIT[1].J,SCN19.HIT[1].K> SCN19_PNT2 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<SCN19.HIT[2].TX,SCN19.HIT[2].TY,SCN19.HIT[2].TZ>,$ MEAS/XYZ,<SCN19.HIT[2].X,SCN19.HIT[2].Y,SCN19.HIT[2].Z>,$ NOM/IJK,<SCN19.HIT[2].TI,SCN19.HIT[2].TJ,SCN19.HIT[2].TK>,$ MEAS/IJK,<SCN19.HIT[2].I,SCN19.HIT[2].J,SCN19.HIT[2].K> . . . . . SCN19_PNT255 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<SCN19.HIT[255].TX,SCN19.HIT[255].TY,SCN19.HIT[255].TZ>,$ MEAS/XYZ,<SCN19.HIT[255].X,SCN19.HIT[255].Y,SCN19.HIT[255].Z>,$ NOM/IJK,<SCN19.HIT[255].TI,SCN19.HIT[255].TJ,SCN19.HIT[255].TK>,$ MEAS/IJK,<SCN19.HIT[255].I,SCN19.HIT[255].J,SCN19.HIT[255].K> SCN19_PNT256 =GENERIC/POINT,DEPENDENT,CARTESIAN,$ NOM/XYZ,<SCN19.HIT[256].TX,SCN19.HIT[256].TY,SCN19.HIT[256].TZ>,$ MEAS/XYZ,<SCN19.HIT[256].X,SCN19.HIT[256].Y,SCN19.HIT[256].Z>,$ NOM/IJK,<SCN19.HIT[256].TI,SCN19.HIT[256].TJ,SCN19.HIT[256].TK>,$ MEAS/IJK,<SCN19.HIT[256].I,SCN19.HIT[256].J,SCN19.HIT[256].K>
I use scan probably on average 3 times in a month. I only use them if I have the UG file mainly to just create a surface and overlay it with the UG file. The engineers seemed to really like that for a visual on how the part is for profile.DEA MISTRAL
PC DMIS CAD++
Version 2013
Windows 7 64bit
DataPage+ 2011 MR1
We use them for about 75% of our work. We are inspecting molding components for aluminum die cast dies. We check core locations, datums, levels, but since there really arent any part prints for the steel, only models, scanning gives us the best and quickest alternative with a sp600. We create easy to read reports for the toolmakers in charge of the dies. These reports show the washed out areas, material safe areas, ect...sigpic
by mange34I have a problem with scaning compared to a 3D part .
I want to scan the light blue surface as you can see on the pix i have instert....-
09-13-2007, 09:44 AM -
by AnkleWearHello all,
I have an ankle implant that I will be testing for wear. I'm using our CMM to measure the surface of the part, then take scans...-
10-05-2015, 04:50 PM -
by quality2214Thanks for all your help on the other posts. You all have been such a great help. Last question I hope. I am instructed to digitize a clamp shell so...
12-12-2006, 09:53 AM -
by davey cPhoto of die attached that I am being asked to provide data on. What's the best way of going about this ??? I have very little reverse eng experience...
09-20-2006, 04:31 PM -
by sfieldMy question has to do with some scanning issues that I have recently seen. I was doing open and closed scans on parts with helices. I did some scans vertically...
10-16-2017, 09:49 AM -
