I have the following dimension. TP|.1m|Dm. This is a circle on a plane that is TP to another Circle (Datum D) on the same plane. Am I allowed to add bonus from each circle to the TP tolerance? How do you calculate it for both?
bonus from MMC question
From the first, yes. From the second (-D-), no. The second is for datum shift on a hard gage. I would add that if no other features are positioned from -D- then adding that bonus would be fine.
I'll leave it to Kev, our resident GD&T guru to correct and clarify.
TKsigpicHave a homebrew
Originally posted by calbritton View PostI have the following dimension. TP|.1m|Dm. This is a circle on a plane that is TP to another Circle (Datum D) on the same plane. Am I allowed to add bonus from each circle to the TP tolerance? How do you calculate it for both?
http://i102.photobucket.com/albums/m...ueposition.jpgLast edited by Don Henger; 04-04-2007, 10:25 AM.sigpicRegards,
Donald Henger
B&S Micro Excel Pfx
3.5mr2 & 3.7mr3
PHH10MQ, TP20 & TP2
Country Rocks,But Bluegrass RULES!!!
You're using 4.1. Use the XactMeasure GD&T, and it will handle the bonus correctly. No need to try to do additional math...
If D does have a virtual condition, PC-DMIS will also take that into account. Be careful though: read the portion in ASME Y14.5 on "Simultaneous Requirements". You can set this (and I verified that it works!) under Insert/Dimensions/Simultaneous Evaluation . Thanks to Mr. Botta, I am now doing this right.
Originally posted by calbritton View PostI am not familiar with XactMeasure GD&T. Is that part of 4.1?
Now go back to Insert/Dimension/Perpendicularity. That pops up a window called "XactMeasure GD&T - Perpendicular Dimension". follow the instructions. It is pretty simple to work wth these things...
Tip: Also, if your using 4.1 never create or define a Datum to a feature set. Unless of course you want to Delete your program without warning.
If your Datum is pattern of features, you have to use v4.2.Mr. Comment
SCIROCCO-NT 13-20-10
Originally posted by MrComment View PostTip: Also, if your using 4.1 never create or define a Datum to a feature set. Unless of course you want to Delete your program without warning.
Woawww, thanks! I have not done this YET! I do have a few parts coming up where I have to get into this. Thanks for the heads-up.
If your Datum is pattern of features, you have to use v4.2.sigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
PCDMIS 2012
Windows Office XP
by SoberYangHello all
The TP dimension of feature with MMC , Both datum B and C with MMC, too.
refer to the attached file.
The bonus...-
12-06-2018, 08:28 AM -
by dph51v4.1
Using legacy dimensioning
I am trying to dimension a feature TP with double bonus.
|TP|0.7 @mmc|-B- @mmc|-C- @mmc|...-
07-14-2010, 01:10 PM -
I need to check the true position of a 4 holes in the x & y direction. The feature is a RFS, however you have a MMC on the -A- datum. I dimensioned...
06-19-2006, 12:50 PM -
by TCROWLEYWhen I run the true position for Circle 1 I get a MMC bonus of .0008" but when I run the true position for circle 2 in relation to circle 1 (datum...
Channel: PC-DMIS Portable
04-17-2014, 05:59 PM -
version 4.2 mr1
I am checking the location of a hole pattern @ .020 mmc to datums A,B,C
D1 - (plane) RFS (A)
D2-...-
03-03-2008, 11:52 PM -
