Dimension to far ends of a radius (not the center)
  • Dimension to far ends of a radius (not the center)
    Someone help me out with something please! I need to report from where my alignment is at right now to both the top and bottom radii in the picture (YAXIS). I put a red dot for clarity. Far ends of the radii.
    Thanks in advance!
    -Bill
    PC-DMIS 4.2 MR1 - Global Image 7107 - PH10MQ - SP600M
    Construct a point at the origin then use distance and select circle options add radius
      Too easy! thank you!!
      -Bill
        That will work well but my preference is to set your xyz origin to the center and report th PR (polar radian) from the Cartesian location icon, to the point, just in case the point is off axis... YOU can also report the PA (polar angle) as reference where the point is... you can do this to multiple points on this radius, without adding the radius.
        • Onehot82
          Polar Raduis
          Onehot82
          I am new to pcdmis and tried searching for this but didnt come up with the right info. I am trying to measure a partial radius using polar radius and...
          02-21-2012, 07:12 AM
        • Terrybike
          A bend centerline radius
          Terrybike
          I've been asked to measure the center line radius of a bend of a tube (see drawing attached) with a very small ark (20 deg) and the tube has deformed...
          04-30-2015, 08:13 AM
        • AuRules
          Checking Radius
          AuRules
          Got a tricky one fellows, how would you go about checking these 2 radius I have pictured in the attachment I need size and location. The bottom part of...
          09-12-2013, 02:11 PM
        • Rob Knoerlein
          Polar radius issues
          Rob Knoerlein
          Does anyone have issues when utilizing polar radius for TP callouts ? I am using version 4.3 and have sort of figured out from trial and error that polar...
          04-17-2009, 09:11 AM
        • dennisgilpin
          Measuring a 1mm radius
          dennisgilpin
          Hi there, I'm trying to find out what is the best way to measure this 1mm radius on the side of my part. I'm using a .5mmx20 probe, taking 8 hits on radius....
          03-05-2013, 11:43 AM
