I will try thi again. I,ve got a program that has been run many times. Today the program runs fine except it skips all scans. I have tried to execute block, execute from curser, and even F9. I can not get them to run. Any ideas?
PC-DMIS v4.1
Try this, F9 one of the scans. Choose all the CAD areas that will be traveled by your probe during the scan, regenerate, run the scan after clicking ok. If the scan runs ok, I would suggest 1. either do this for all of these scans, or 2. move on to 4.2. PM me and I will forward the link for 4.2.
I've tried that and it will not regenerate. It's like the scans are set to a off option. I was able to insert a new scan before my first scan, but any atempt to place one after the first one gives me tha same results "nothing".
I wasn't having much luck with my scans from older programs in 4.1. When I moved on to the 4.2 release candidate I have not had any problems since then. Warning: That doesn't mean that I won't.
I have been running 4.1 sence it was released with no major problems, until now. I have brought 100's of programs up from V3.5 mr1 to V4.1. With little...
Need some Scanning help here. I’m running a BS, Global Reference XI, with a B-4 controller. The software is PC-DMIS 2011, custom built for us. Using...
I have program that I am proving out that has several scans, one right after the other. They are basic circle scans. When placing the cursor on or before...
I’m working on a program that checks 12 parts on a pallet. It ran ok offline for me but on the CMM the program runs around the part but the deviations...
