I have ran Datapage before using MM4 software and had no problems. But since we purchased Datapage with the PCDMIS I started trying to use it today. Seems to be working fine but the command I use STATS/ON shows up in my report, is it suppose to. and do you need the STATS/OFF at the end. I know you fine gentlemen use this all the time and will supply me with some help and do I post it here? are does it really matter!
Stats
by AuRulesI have ran Datapage before using MM4 software and had no problems. But since we purchased Datapage with the PCDMIS I started trying to use it today. Seems...
04-02-2007, 10:36 AM -
by Jonathan SDoes trace field need to follow the stats command? Does it need to be inserted between STATS/ON and STATS/END?
07-29-2008, 09:53 AM -
by inspector212I've seen this twice now. The stats code is in the program but the stats (XSTATS11.tmp) do not send to the PC-DMIS folder. The PCs were restarted but...
05-30-2008, 02:39 PM -
by Jeff HuntI have been having a strange problem. Ocasionally when my program sends stats out, everything will be normal (progress bar pops up). Other times the...
07-17-2009, 09:40 AM -
by Paul Sarrach
I am writing a program that for some reason stopped updating the the Dimensionla output. So I put in a Stats to make it go to datapage. It...
05-09-2006, 11:22 AM -
