construct circle from points in loop
  • construct circle from points in loop
    Good Morning All
    I have punch with gear inside (35 teeth to make math easier) and I need to measure larger diameter.I made loop which takes points between teeth but i have no idea how to construct circle. CMM takes points, I can see them on CAD model but not on any list - just point 1. I would be grateful for any suggestions.
    MOVE/CLEARPLANE
    V1 =LOOP/START,ID=YES,NUMBER=35,START=1,SKIP=,
    OFFSET:XAXIS=0,YAXIS=0,ZAXIS=0,ANGLE=10.286
    PNT1 =FEAT/CONTACT/VECTOR POINT/DEFAULT,POLAR
    THEO/<32.754,270,-2>,<0,1,0>
    ACTL/<32.752,269.998,-2>,<0,1,0>
    TARG/<32.754,270,-2>,<0,1,0>
    SNAP=NO
    SHOW FEATURE PARAMETERS=NO
    SHOW CONTACT PARAMETERS=YES
    AVOIDANCE MOVE=BOTH,DISTANCE=5
    SHOW HITS=NO
    LOOP/END
    Thanks,
    Ewa D.
    I don't know how to see your points, but am interested in the answer. If I had that issue, I'd likely copy the first point, then "paste with pattern" to make the rest. That way, I know they would be out where I could see/ find them. Looking forward to reading about other options!
      Wrong answer hold up. Miss read the question
      • Kp61dude!
        Kp61dude! commented
        beat ya!!! vvvvvvvvvvv
      Looping 4 times
      v1         =loop/start,id=yes,number=4,start=1,skip=,
                    offset:xaxis=0,yaxis=0,zaxis=0,angle=90
      pnt2         =feat/contact/vector point/default,cartesian
                    theo/<1.1909,0,-0.1>,<-1,0,0>
                    actl/<1.1909,0,-0.1>,<-1,0,0>
                    targ/<1.1909,0,-0.1>,<-1,0,0>
                    snap=no
                    show feature parameters=no
                    show contact parameters=yes
                      avoidance move=no,distance=0.3937
                    show hits=no
                  loop/end
      cir7       =feat/circle,cartesian,out,least_sqr,no
                  theo/<0,0,-0.1>,<0,0,1>,2.3818
                  actl/<0,0,-0.1>,<0,0,1>,2.3818
                  constr/circle,bf,2d,pnt2[1],pnt2[2],pnt2[3],pnt2[4],,
                  outlier_removal/off,3
                  filter/off,upr=0
      just keep adding pnt<num>[index] until you reach all 35.
      PcDmis 2015.1 SP10 CAD++
      Global 7-10-7 DC800S
      • KIRBSTER269
        KIRBSTER269 commented
        good I don't have to post LOL. You got it
      • Krisj
        Krisj commented
                    constr/circle,bf,2d,pnt2[1..4],,
                    filter/off,upr=0
        Just to tack on, you can do this instead of each point individually
      • Kp61dude!
        Kp61dude! commented
        I was tempted to try this ^^^^ after I posted but failed to go back and give it a try as I was not sure if it would have worked or not. Thanks for posting @Krisj!!! How about you make it a real post, instead of a comment, so others will run right into it, it's a huge time saver. Way better than typing up pnt1[1] thru pnt1[35]!!!!
      Unfortunately it does not work. PC-DMIS wouldn't construct BF circle from 1 point, it constracted cast circle, I have made changes manually and added points as advised but when I run program at the end of execution i get construction error. And it measures 1mm, i tired to enter 65 (mine dia), no difference
      ‚Äč
        Construct it from that one point as cast then in the Edit window change cast to bf (best fit), you will see an error message...ignore it. Change pnt<num> to pnt<num>[index], you will get another and another error message until you have 3 pnt<num>[index] in there (constructing a circle is 3 points minimum). You will stop seeing the errors after the 3rd point, continue typing in your pnt<num>[index]
        In other words don't use the construct command window to handle this one, Edit window editing only. Well besides creating the initial constructed circle to work with, it can be constructed from anything (legal) just to populate the PcD code in the Edit Window and avoid any error pop-up.
          For some reason it doesn't accept single points like pnt1[1],pnt1[10],pnt1[20],, but works with pnt1[1..35],,
          thanks
          THEO/<32.754,270,-3>,<0,1,0>
          ACTL/<32.752,270,-2.999>,<0,1,0>
          TARG/<32.754,270,-3>,<0,1,0>
          SNAP=NO
          SHOW HITS=NO
          LOOP/END
          CIR4 =FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR,NO
          THEO/<0,0,-3>,<0,0,1>,65.508
          ACTL/<-0.002,0.003,-3>,<0,0,1>,65.511
          CONSTR/CIRCLE,BF,2D,PNT1[1..35],,
          OUTLIER_REMOVAL/OFF,3
          FILTER/OFF,UPR=0
          DIM LOC1= LOCATION OF CIRCLE CIR4 UNITS=MM ,$
          D 65.508 0.005 0.005 65.511 0.003 0.000 --------------#---
          END OF DIMENSION LOC1
            PC-DMIS is not consistent - in some places it only accepts ranges, in others single points. If you need to reference a single point and PNT1[1] gives an error, try PNT1[1..1]
