I have ran Datapage before using MM4 software and had no problems. But since we purchased Datapage with the PCDMIS I started trying to use it today. Seems to be working fine but the command I use STATS/ON shows up in my report, is it suppose to. and do you need the STATS/OFF at the end. I know you fine gentlemen use this all the time and will supply me with some help and do I post it here are does it really matter?
Stats
Originally posted by Matthew D. Hoedeman View PostYes, it will show up and no, you don't need a stats off, in fact, don't use it.sigpicRegards,
Donald Henger
B&S Micro Excel Pfx
3.5mr2 & 3.7mr3
PHH10MQ, TP20 & TP2
Country Rocks,But Bluegrass RULES!!!
Originally posted by Don Henger View PostJust to be curious. I have always used stats off but just before stats off I always put update stats. So is there a reason not to use stats off?? I just always used it because of mm4 you had to.sigpic
Originally posted by Matthew D. Hoedeman View PostNope, I have never found a reason to use it. The ONLY time it shows up in my program is if I toggle the STAS ON command to STATS off. This will prevent any data from being saved to the stat file but it will 'remember' all the database paths you used so when you toggle it back on, they are still what they were before you toggled it off.sigpicRegards,
Donald Henger
B&S Micro Excel Pfx
3.5mr2 & 3.7mr3
PHH10MQ, TP20 & TP2
Originally posted by Don Henger View PostJust to be curious. I have always used stats off but just before stats off I always put update stats. So is there a reason not to use stats off?? I just always used it because of mm4 you had to.Last edited by AuRules; 04-02-2007, 05:03 PM.sigpic
Originally posted by AuRules View PostDon ou are correct in MM4 you had to use STATS/OFF, but I tried it this morning with removing the STATS/OFF and it worked. and also if you choose F5 there is a place under the Dimension tab where you can tell it to update all the time for all programs.sigpicRegards,
Donald Henger
B&S Micro Excel Pfx
3.5mr2 & 3.7mr3
PHH10MQ, TP20 & TP2
Originally posted by JamesMannes View PostThat is a true statement, but, if you loop your program to run another, either with a question (do you want to run another part?) or an automated looping, you will need to put in the STATS/UPDATE command. Otherwise you will only have 1 statistic set saved (say you run 10 pieces; you will only get the last piece if there isn't a STATS/UPDATE command telling DMIS to send the stats.
THANKS you ALLsigpic
by AuRulesI have ran Datapage before using MM4 software and had no problems. But since we purchased Datapage with the PCDMIS I started trying to use it today. Seems...
04-02-2007, 10:37 AM -
by inspector212I've seen this twice now. The stats code is in the program but the stats (XSTATS11.tmp) do not send to the PC-DMIS folder. The PCs were restarted but...
05-30-2008, 02:39 PM -
by Jonathan SDoes trace field need to follow the stats command? Does it need to be inserted between STATS/ON and STATS/END?
07-29-2008, 09:53 AM -
by Jeff HuntI have been having a strange problem. Ocasionally when my program sends stats out, everything will be normal (progress bar pops up). Other times the...
07-17-2009, 09:40 AM -
by Paul Sarrach
I am writing a program that for some reason stopped updating the the Dimensionla output. So I put in a Stats to make it go to datapage. It...
05-09-2006, 11:22 AM -
