2017 r2 sp9
  • 2017 r2 sp9
    Here :
    http://software.hexagonmi.com/public...1340.0_x64.exe
    Release Notes - 2017 R2 SP9
    • PCD-95827 - Fixed an issue where PC-DMIS did not create an alignment correctly for a datum feature when you defined the datum before the alignment.
    • PCD-111909 - Fixed an issue for colormap arm assignment for dual-arm machines. If the current arm assignment of the colormap was one of the reference command (COP) arm assignments, and the pointcloud surface colormap was edited, then the arm assignment did not change. However, if the current arm assignment of the colormap was different than the currentreferenced COP arm assignment, then the colormap arm assignment changed to reflect the current reference COP arm assignment.
    • PCD-127830 - On the Clip Planes tab in the CAD and Graphic Setup dialog box, fixed the capability to select a CAD surface in the Graphic Display window.
    • PCD-131840 - Fixed an issue where the manual temperature compensation wasn't working in combination with the new Temperature Compensation Setup dialog box.
    • PCD-135273 - Fixed an execution problem of a Cylinder Auto Feature outer on Arm2, where a MOVE/POINT programmed after the AF was done inbetween the sample hits of the Cylinder Auto Feature.
    • PCD-138460 - Fixed an issue where incorrect colormaps were shown on some CAD parts.
    • PCD-139451 - Fixed an issue where a "No laser scan data" error appeared for all direct-measured laser features in measurement routines in inch units.
    • PCD-139717 - Fixed an issue that infrequently occurred on certain Windows 7 machines where the tolerance value was also entered as the thickness value in the Pointcloud Operator dialog box for a Surface Colormap operator.
    • PCD-140397 - Fixed an issue where Wcompens32_2.dll did not correctly load the geometrical compensation map on DEA machines.
    • PCD-140785 - Fixed the issue of an incorrect path for an auto feature cylinder spiral scan.
    • PCD-141332 - Fixed a corner-case issue in the CAD Assembly dialog box when geometry was moved to different parts, which may have caused problems with the transformation of the geometry.
    • PCD-141372 - Fixed an issue where multi-thread access to the Automation interface caused a random "marshalling" error message.
    • PCD-141398 - Fixed an issue for portable laser scanning where the processing of the laser stripes received from RomerRDS caused a lag in performance.
    • PCD-141724 - I++ tags can be duplicated for tag ranges (e.g.: Get(X(),Y(),Z()).
    • PCD-141784 - Fixed an issue with error recovery for PC-DMIS running with technology server with a LEITZ CMM and rotary table (4-axis scanning().
    • PCD-141803 - Fixed an issue where the T value that appeared in the Probe Readouts window displayed incorrectly for a tracker using a reflector.
    • PCD-141870 - I++ client allows to switch axes.
    • PCD-142013 - Fixed an issue where legacy reports with text labels where not scaled-to-fit correctly.
    • PCD-142188 - Fixed an issue where the leader line termination points were not correct for the analysis view command when a CMM transform was used.
    • PCD-142299 - Fixed an issue with the Mirror command where the CAD was mirrored (flipped) along the wrong axis.
    • PCD-142652 - Updated the "learn more" links on the What's New pages in PCDMIS to fix the broken links caused by changing to a new support center.
    • PCD-143634 - Fixed a random crash that occurred in Operator Mode and Protected Mode, or after the custom menu items were adjusted.
    • PCD-145385 - Corrected an import issue where large IGES files would hang indefinitely under certain conditions.
    • PCD-145450 - Fixed an issue where PC-DMIS stopped working when GD&T items were selected.
    • PCD-145736 - The ZEISS configuration file stored in the PC-DMIS installation directory is now opened with reading access mode. This is important for more restrictive user-access rights on Windows 10.
    • PCD-145795 - The optics calibration and illumination calibration was changed to support hardware where the illumination gets brighter very quickly. This change does not affect existing calibration data and thus does not require any recalibration unless poor calibrated illumination behavior has been seen. This fixes an issue that generated a "Failed to set lighting brightness" error message during pixel size calibration.
    JEFMAN
    PC-DMIS Ultra Guru
    JEFMAN Thx for posting!
    I like this:
