Probably a dumb question...
  • Probably a dumb question...
    We are trying to upgrade to a newer PC on our older Xcel. Unfortunantly, I did not look at the hook-ups for the CMM. The older PC had 2 ( I believe they are called I/O ports ) and the new PC has only one. Am I screwed on this? I think my choices are to get a differnet PC with the correct ports or get a new controller for the CMM. That sound right??
    Thanks for listening..
    You should be able to take the card out of the old PC and put it in the new one unless there is not room for the new card, which there should be???
    PCDMIS 2012
    Windows Office XP
      Gotta watch that, the old card might be an 8 or 16 bit card, in which case you probably can't put it in the new PC.
        I never even thought about that (needed some more sleep today)...
        PCDMIS 2012
        Windows Office XP
          If you are looking at a Serial port (9-pin configuration), you can typically get a Serial-to-USB adapter and use a USB port on the new PC.
          sigpic:rolleyes:
            Is it seriously that easy?? Geez man don't tease me.....
              If what you need is Serial ports, then yes it is that easy. I have used them... no wait, I'm using one now.
              Are there special cards installed in the PC (as Matt pointed out)
                I am also currently using a SERIAL port to USB convertor on the PH9 input.This was fitted by a Hexagon Metrology guy when he came to do the migration from the old PC to the new PC.
                It's only a mistake if somebody else finds it!
                  Gee John,
                  Couldn't ask me to help? I have done it 4 or 5 times. It is MY old CMM afterall.
                    Oh yes. It is just a serial port. If I remember right, there is a serial port card in the old computer. If not then there should be one in our computer junk room.
                      Originally posted by NANCY R View Post
                      Gee John,
                      Thought you were too busy. Didn't want to bother you.
                      I went to Best Buy and got an adapter cord.
                      Now if I had some time to swich them over....
