Did anyone use ACR3 ever before? If so, could u give me some supports about how to use ACR3 with PCDMIS! Or ,if u can give me some manuals, I'd really very appreciate your help! Thanks!
Help! ACR3
Same as other racks
I've used it, many times. You did not ask about calibrating it, that's a little bit of a pain compared to some other racks. It involves using a feeler gauage in slot 1 and touching off on top and in front, before proceeded to probe other slots in DCC.
Using the rack itself is no different than others. You simply need a LoadProbe statement in your program, and have the proper probes defined in the slots.
is it calibration you are having questions on? If so, which part of it? -
not like SCR200\MCR20
Thanks! Yes, it's a painful job to calibrate it. We bought the rack but no one could use it for it would go a wrong way after we calibrated it by the guiding steps in the pcdmis. We can finish the calibration, but it will go a wrong way when we do a LoadProbe statement in my program. Does anyone now why??The content mind is the greatest happiness a man can enjoy in the world.......
SHEFFIELD CMM
PCDMIS V3.7/V4.1/V4.2........Comment
Please elaborate
What do you mean "it goes a wrong way"? Where does it go? Dos it do this when dropping off a probe, picking up a probe, or both? Does it happen before or after?
Did you define the Move Point (one of the calibration tabs)? Does it move toward the machine's origin?Comment
How do I "Inhibit the probe tip"? The ACR3 instructions recommend that I do this in PC-DMIS, but I don't know how. Help please.Comment
by plowboyAny one have the proper instructions for calibration of the SCR 200 rack?
The on screen prompts and the help file instructions are different and...-
09-02-2011, 09:53 AM -
by QE161I'm looking fo a little help with an issue I'm having with calibrating my probe rack. I start the rack calibration process and take the 3 points on the...
10-29-2008, 01:16 PM -
Hey all i am trying to help someone out with adding a probe rack. They are using 2010mr3 and it is the SCR200 rack. We can get it through the calibration...
06-22-2011, 08:40 AM -
by SchlagInteresting issue I am running into. After having to replace the computer on 1 of my globals I am trying to get it back up and running. I copied the probes...
09-20-2018, 01:01 PM -
I have a Brown and sharp Image with a probe rack. normally I am able to calibrate the entire rack and the do a probe to probe verification to make sure...
06-29-2018, 02:11 PM -
