# Of Points for Adaptive Circle Scan
  • # Of Points for Adaptive Circle Scan
    Good Morning,
    New to scanning. Took level 2 back in February. Tigo getting installed next week. Upgraded offline seat from 2016 CAD to 2018 CAD++ a few weeks ago. So i'm re doing my courses offline and I'm mainly interested in Adaptive Circle Scan.
    How do I control the number of points in a adpt circ scan? It looks like no matter what I change the point density to in the override dialog box, the scan path is always around 188 points. Can I control it to be 300 or 500?
    Another thing is that I work with standard units and most of the course is in metric so its a little tricky converting things. Are point density and scan speed always in metric?
    for the adaptive circle scan - Advanced tab, the default point density (on my machine) is 6 pts/mm if i need more i usually bump it to 60 to see what it does then play with it from there. yes the advanced tab is always in metric. hope this helps
    • acgarcia
      acgarcia commented
      Just to be clear, 6 pts/mm means the machine will take 6 points per mm scanned?
    • mckenzie
      mckenzie commented
      yes exactly
    if you look at the status window after the circle is measured how close to nominal was the hole? if the hole location is too far of f the nominal the probe might not be touching the wall all the way around the circle limiting the # of hits registered
      Used this method in circle scans.
      Need to calculate FILTER/DISTANCE
      Ex Diameter = 50.8
      100 arc segments
      ASSIGN/PI = ACOS(0)*2
      ASSIGN/D1 = 50.8
      ASSIGN/C1 = PI*D1
      ASSIGN/NUM_ARCS = 100
      ASSIGN/FILTER_DISTANCE = C1/NUM_ARCS
      plug filter_distance into the scan component FILTER/DISTANCE
      Hope this helps, you know today being Friday the 13th and all.
      • acgarcia
        acgarcia commented
        lol, its definitely an offline day today.
