Alignment issue
  • Alignment issue
    Hi everyone , I am creating an ABC datum alignment datum A is the floor of the part datum B IS a .250" diameter hole in the floor, the datum C is flange at 87degree to datum A.
    - In my alignment I level with datum A translated my Z to datum A,
    - rotated with a line on datum C
    - translated my X AND Y to cylinder B (datum B).
    with this alignment I am getting a .009" error in X .Could the be because I did not translate my X to datum C, OR should I have use an iterated alignment?
    I would’ve done an iterative alignment. Try that. The IA should clear up the error.
    Darroll
    2018R2
      Thank u
        So, you are clocking the alignment to a flange that is 87 deg.
        Q. Is the dimension (showing 0.009" error) called out to be square to this flange?
        sigpicIt's corona time!
          The error dimensions are not square to the flange
          • Roberto
            Roberto commented
            That's why the dimensions are coming out skewed.
            You should use the offset angle (i.e. 3 deg) to bring the dimensions "parallel" with the object.
            Unless I'm missing something.
          Measure datum C as a plane and rotate to that.
          • Steve R
            Steve R commented
            "Rotate to that" means rotate to the 3 degree. Angle?
          • RandomJerk
            RandomJerk commented
            When you're rotating to a 3D feature, the vector component of the "about" axis is ignored. I've done it plenty of times, and I've checked it quite a few, it works fine.
            If it's a really big concern, though, intersect the two planes and use the generated line for the rotation.
