I have pcdmis pro 3.7 maintanece release 2 and was wondwering how to do something I have a round part that has a square hole with rounded corners in the middle of it and I need to make the square the center of my part also I got to take 50 hits in it
square hole
Whaaaaa?
You are REQUIRED to take 50 hits in the square hole?
If you have to do that, then you will have to do a scan in it. No way to do that with an auto feature. If you do not have DCC Scanning, then you will have to take a BUTT load of edge points, make a feature set and go from there.sigpic
Originally posted by AndersII've got one from September 2006 (bug ticket) which has finally been fixed in 2013. -
Well, IF you ahve a 'full' version of Pcdmis, you CAN do a SQUARE SLOT which will give you the center of the hole.
Do do lines, etc., you measure 2 (or more) edge points on each side of the square, intersect the lines at the corners, construct lines from the corner intersects, then construct a point at the intersection of those 2 lines. In this case, I would start by doing the square slot anyway, then use it for the alingment origin (with it set to remeasure), then go to the points/lines/etc.sigpic
Originally posted by AndersII've got one from September 2006 (bug ticket) which has finally been fixed in 2013.Comment
It may look like this. Take note tho I did not use edge points and did not adjust the hits to be correct but you should be able to follow.
PNT13 =FEAT/POINT,RECT
THEO/1.714,-9.148,-3.843,0,1,0
ACTL/1.714,-9.148,-3.843,0,1,0
MEAS/POINT,1
MOVE/CLEARPLANE
HIT/BASIC,1.714,-9.148,-3.843,0,1,0,1.714,-9.148,-3.843,USE THEO = YES
ENDMEAS/
PNT14 =FEAT/POINT,RECT
THEO/2.73,-9.145,-3.858,0,1,0
ACTL/2.73,-9.145,-3.858,0,1,0
MEAS/POINT,1
MOVE/CLEARPLANE
HIT/BASIC,2.73,-9.145,-3.858,0,1,0,2.73,-9.145,-3.858,USE THEO = YES
ENDMEAS/
LIN7 =FEAT/LINE,RECT,UNBND
THEO/1.714,-9.148,-3.843,0.9999956,0.0029735,0
ACTL/1.714,-9.148,-3.843,0.9999956,0.0029735,0
CONSTR/LINE,BF,2D,PNT13,PNT14,,
PNT15 =FEAT/POINT,RECT
THEO/1.712,-7.831,-3.882,0,-1,0
ACTL/1.712,-7.831,-3.882,0,-1,0
MEAS/POINT,1
MOVE/CLEARPLANE
HIT/BASIC,1.712,-7.831,-3.882,0,-1,0,1.712,-7.831,-3.882,USE THEO = YES
ENDMEAS/
PNT16 =FEAT/POINT,RECT
THEO/2.723,-7.822,-3.835,0,-1,0
ACTL/2.723,-7.822,-3.835,0,-1,0
MEAS/POINT,1
MOVE/CLEARPLANE
HIT/BASIC,2.723,-7.822,-3.835,0,-1,0,2.723,-7.822,-3.835,USE THEO = YES
ENDMEAS/
LIN8 =FEAT/LINE,RECT,UNBND
THEO/1.712,-7.831,-3.882,0.9999592,0.0090375,0
ACTL/1.712,-7.831,-3.882,0.9999592,0.0090375,0
CONSTR/LINE,BF,2D,PNT15,PNT16,,
PNT17 =FEAT/POINT,RECT
THEO/1.555,-7.999,-3.848,1,0,0
ACTL/1.555,-7.999,-3.848,1,0,0
MEAS/POINT,1
MOVE/CLEARPLANE
HIT/BASIC,1.555,-7.999,-3.848,1,0,0,1.555,-7.999,-3.848,USE THEO = YES
ENDMEAS/
PNT18 =FEAT/POINT,RECT
THEO/1.568,-8.989,-3.877,1,0,0
ACTL/1.568,-8.989,-3.877,1,0,0
MEAS/POINT,1
MOVE/CLEARPLANE
HIT/BASIC,1.568,-8.989,-3.877,1,0,0,1.568,-8.989,-3.877,USE THEO = YES
ENDMEAS/
LIN9 =FEAT/LINE,RECT,UNBND
THEO/1.555,-7.999,-3.848,0.0136281,-0.9999071,0
ACTL/1.555,-7.999,-3.848,0.0136281,-0.9999071,0
CONSTR/LINE,BF,2D,PNT17,PNT18,,
PNT19 =FEAT/POINT,RECT
THEO/2.879,-7.988,-3.866,-1,0,0
ACTL/2.879,-7.988,-3.866,-1,0,0
MEAS/POINT,1
MOVE/CLEARPLANE
HIT/BASIC,2.879,-7.988,-3.866,-1,0,0,2.879,-7.988,-3.866,USE THEO = YES
ENDMEAS/
PNT20 =FEAT/POINT,RECT
THEO/2.877,-9.004,-3.858,-1,0,0
ACTL/2.877,-9.004,-3.858,-1,0,0
MEAS/POINT,1
MOVE/CLEARPLANE
HIT/BASIC,2.877,-9.004,-3.858,-1,0,0,2.877,-9.004,-3.858,USE THEO = YES
ENDMEAS/
LIN10 =FEAT/LINE,RECT,UNBND
THEO/2.879,-7.988,-3.866,-0.0020465,-0.9999979,0
ACTL/2.879,-7.988,-3.866,-0.0020465,-0.9999979,0
CONSTR/LINE,BF,2D,PNT19,PNT20,,
PNTBL =FEAT/POINT,RECT
THEO/1.57,-9.149,-3.845,0.9999956,0.0029735,0
ACTL/1.57,-9.149,-3.845,0.9999956,0.0029735,0
CONSTR/POINT,INT,LIN7,LIN9
PNTBR =FEAT/POINT,RECT
THEO/2.877,-9.145,-3.854,0.9999956,0.0029735,0
ACTL/2.877,-9.145,-3.854,0.9999956,0.0029735,0
CONSTR/POINT,INT,LIN7,LIN10
PNTTL =FEAT/POINT,RECT
THEO/1.552,-7.833,-3.865,0.0136281,-0.9999071,0
ACTL/1.552,-7.833,-3.865,0.0136281,-0.9999071,0
CONSTR/POINT,INT,LIN9,LIN8
PNTTR =FEAT/POINT,RECT
THEO/2.88,-7.821,-3.874,0.9999592,0.0090375,0
ACTL/2.88,-7.821,-3.874,0.9999592,0.0090375,0
CONSTR/POINT,INT,LIN8,LIN10
LIN11 =FEAT/LINE,RECT,UNBND
THEO/2.877,-9.145,-3.854,-0.7104496,0.7037481,0
ACTL/2.877,-9.145,-3.854,-0.7104496,0.7037481,0
CONSTR/LINE,BF,2D,PNTBR,PNTTL,,
LIN12 =FEAT/LINE,RECT,UNBND
THEO/1.57,-9.149,-3.845,0.7020989,0.7120795,0
ACTL/1.57,-9.149,-3.845,0.7020989,0.7120795,0
CONSTR/LINE,BF,2D,PNTBL,PNTTR,,
PNTCENTER =FEAT/POINT,RECT
THEO/2.218,-8.492,-3.85,-0.7104496,0.7037481,0
ACTL/2.218,-8.492,-3.85,-0.7104496,0.7037481,0
CONSTR/POINT,INT,LIN11,LIN12sigpic
if you had soap on a rope it would be tied to yer ankleComment
Whaaaaa?
If you have to do that, then you will have to do a scan in it. No way to do that with an auto feature. If you do not have DCC Scanning, then you will have to take a BUTT load of edge points, make a feature set and go from there.Comment
I want to know more about these 50 hits. Is that 50 total so 12.5 on each side? Or is it 50 for each side? Could you measure a line on each side then go back, F9 the feature, change the number of hits to 50, check "regenerate hits" and click ok. Then, you would have 50 hits evenly spaced between the two end points of the lines (50 is inclusive to the two end points). Then, you could use these hits in whatever manner you like... LIN1.HIT(1..50).X...
Perhaps is a "dish" and the 50 points need to be taken on the curved surface?
just wondering.sigpicIt's corona time!
737 Xcel Cad++ v2009MR1....SE HABLA ESPAÑOLComment
How deep is the square hole? How big is it ?
Do you have a pic of the callout? If it is a deep and small broached hole you may shank out
(go for it)
Tolerance challenged ... Living in the world of unseen lines.
This software isn't buggy its an infestationComment
I have a square hole to measure 10mm x 10mm, and I have different tolerances on the width and length.
How do I determine what pcdmis calls the...-
04-28-2006, 09:06 AM -
by ag162Here is one more,
I have a square slot, it has a recessed area, kinda like a strengthening bead. If I use the auto feature, it attempts to find...-
05-30-2007, 11:00 AM -
by #2#Anyone know if there is a way to change the check depth when doing a find hole?
I have a small hole that I want to use the find hole on....-
08-23-2006, 08:30 AM -
by #2#I just started using 3.7 MR3. I did not notice this problem with MR2. When using the find hole function if the tip starts into the hole and then hits...
05-18-2006, 04:18 PM -
by Bill GTrying to get a 1mm probe to take hits (in cad) on a .076 hole. Never can get it correct these days. Program keeps asking me if I want to change workplanes....
08-20-2015, 01:23 PM -
