Can anyone tell me what command changes everything to metric?
Changing to Metric
Dividing everything by 0.03937 or multiplying it by 25.4. You are stuck in inches brother the only time you can decide is when you create the program. Dimensions have a toggle that says IN right now that can be highlighted and changed to MM. But everything else is unchangeable.<internet bumper sticker goes here>
Originally posted by bpennings View PostCan anyone tell me what command changes everything to metric?
If a program is created in ENGLISH, it stays in ENGLISH
If it is created in METRIC, it stays in METRIC.
HOWEVER, you can toggle the dimensions to report in either English or Metric. If the dimensions are already created, you get to do this one at a time, if they are not yet created, you can select which you want to use when you create them.sigpic
When you first start to make a new program an option comes up to use eng/met - also Wilcox site has a script to change the unit back and forth
http://www.wilcoxassoc.com/perl/secu...trepository.plsigpic
When you create a new program you have that option. If you are already in an existing program and its in inches & want to go to mm you have to that option in your dimension boxes.
[email protected] i'm slowsigpic.....Its called golf because all the other 4 letter words were taken
Originally posted by T Miller View PostWhen you first start to make a new program an option comes up to use eng/met - also Wilcox site has a script to change the unit back and forth
Originally posted by Goodluck View PostOne would think that an advanced, powerful software package such as PC-DMIS would have a toggle switch somewhere. Either that or do it like when you mirror a program. Of course, they would screw something else up if they added this feature.sigpic
by VONDYI believe I know this answer already, but is there a way to take a program made in inches and copy\rename\re-(something)\ to make it into metric. I have...
05-19-2006, 01:06 PM -
by jlefave60Hi,
I'm running ver. 3.5. Is there a way to toggle an existing program between metric and inch without having to rewrite the program?-
02-25-2010, 09:17 AM -
by RplougheIs there a way to have Pc DMIS report out both Metric and Standard Results to a report? The shop I currently work for have a Metric Phobia and the operators...
03-04-2014, 08:27 AM -
by ClayOgreI have two parts which are virtually identical, except one is metric and one is inch. The inch part is measured with the part oriented a particular way...
01-11-2008, 07:55 AM -
by EEC1959is there any way to convert an inch program into a metric program without having to go in and switch each characteristic?
01-26-2011, 02:00 PM -
