Scan001.PDF
How do I Project the .307 diameter to the plane at 9 degrees?
It seems that, no matter what I try, the diameter projects parallel to the plane. The deeper I measure the diameter, the farther it is off centerline in the opposite way of the .080 dimension. (see attachment).
How do I get the diameter to project to the plane along the 9 degree axis? I can measure two diameter, create a line but then I cannot get the True Position at MMC that the drawing requires on the .307 diameter.
Alignment is rotated 9 degree.
XY and Z are 'zero' at port centerline/face.
3.7 MR2
Thanks again.
3.7 MR2
Thanks again.
