I have a true postion tolerance for this measurement. It includes max material condition for the feature. The problem is the feature as I have created it is a mid-point. See attached dwg. the true position would end up 2 x the deviation in the X direction. Any suggestions?
True Postion tolerance
Here is something I did quick, just an example....could get you started.
DIM DIST2= 2D DISTANCE FROM POINT PNT1 TO POINT PNT2 PERP TO YAXIS, NO_RADIUS UNITS=MM ,$
GRAPH=OFF TEXT=OFF MULT=5.00 OUTPUT=STATS
M 18.900 0.040 0.070 18.900 0.000 0.000 -----#---
ASSIGN/V1 = IF(DIST2.M.OUTTOL==0.00,ABS(DIST2.M.MEAS-18.94),0.00)
ASSIGN/V2 = V1+.10
DIM LOC1= TRUE POSITION OF POINT PNT3 UNITS=MM ,$
GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER
AX NOMINAL +TOL -TOL BONUS MEAS DEV OUTTOL
X 0.000 -0.041 -0.041
TP RFS V2 0.000 0.082 0.000 -----#---
END OF DIMENSION LOC1sigpic.....Its called golf because all the other 4 letter words were taken
Another option would be to measure the feature with two points as you mentioned previous. Construct a midpoint from these two points then construct a min circsc external circle through these three points which will automatically capture the 18.9 size.
As long as you are in the correct alignment, simply select true position, apply MMC, enter 0.1 as the geometric tolerance, set the circle tolerance as the tolerance of your feature (+0.04, -0.07) and pick the correct axis
I have constructed this with generic features below to give you an idea. Hope this helps
F1 =GENERIC/POINT,DEPENDENT,RECT,$
NOM/XYZ,0,0,0,$
MEAS/XYZ,0,0,0,$
NOM/IJK,0,0,1,$
MEAS/IJK,0,0,1
F2 =GENERIC/POINT,DEPENDENT,RECT,$
NOM/XYZ,18.9,0,0,$
MEAS/XYZ,18.9,0,0,$
NOM/IJK,0,0,1,$
MEAS/IJK,0,0,1
PNT1 =FEAT/POINT,RECT
THEO/9.45,0,0,0,0,1
ACTL/9.45,0,0,0,0,1
CONSTR/POINT,MID,F1,F2
A2 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
ALIGNMENT/TRANS,XAXIS,PNT1
ALIGNMENT/END
CIR1 =FEAT/CIRCLE,RECT,OUT,MIN_CIRCSC
THEO/0,0,0,0,0,1,18.9
ACTL/0,0,0,0,0,1,18.9
CONSTR/CIRCLE,BF,F1,F2,PNT1,,
OUTLIER_REMOVAL/OFF,3
FILTER/OFF,UPR=0
DIM LOC1= TRUE POSITION OF CIRCLE CIR1 UNITS=IN ,$
GRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH DEV PERPEN CENTERLINE=OFF DISPLAY=DIAMETER
X 0.0000 0.0000 0.0000
DF 18.9000 0.0400 -0.0700 0.0400 18.9000 0.0000 0.0000 -----#---
TP MMC 0.1000 0.0400 0.0000 0.0000 #--------
My method is similar to the others.
SLT_1 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
THEO/-0.2175,-0.215,0.305,1,0,0
ACTL/-0.2171,-0.215,0.305,1,0,0
TARG/-0.2175,-0.215,0.305,1,0,0
THEO_THICKNESS = 0,RECT,SNAP = YES,$
AUTO MOVE = NO,DISTANCE = 0.2
SLT_2 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
THEO/-0.2175,-0.215,-0.45,1,0,0
ACTL/-0.2172,-0.215,-0.45,1,0,0
TARG/-0.2175,-0.215,-0.45,1,0,0
SLT_3 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
THEO/0.2175,-0.215,-0.45,-1,0,0
ACTL/0.218,-0.215,-0.45,-1,0,0
TARG/0.2175,-0.215,-0.45,-1,0,0
ASSIGN/SLT_V1 = SLT_3.X-SLT_2.X
SLT_CPT1 =FEAT/POINT,RECT
THEO/0,-0.215,-0.45,0,-1,0
ACTL/0.0004,-0.215,-0.45,-0.0018643,-0.9999954,0.0024068
CONSTR/POINT,MID,SLT_2,SLT_3
ASSIGN/SLT_V2 = SLT_CPT2.X
ASSIGN/SLT_V3 = SLT_CPT2.Y
ASSIGN/SLT_V4 = SLT_CPT2.Z
F3 =GENERIC/CIRCLE,DEPENDENT,RECT,IN,$
NOM/XYZ,0,-0.215,-0.45,$
MEAS/XYZ,SLT_V2,SLT_V3,SLT_V4,$
NOM/IJK,0,-1,0,$
MEAS/IJK,0,-1,0,$
DIAMETER/0.435,SLT_V1
SLT_4 =AUTO/VECTOR POINT,SHOWALLPARAMS = YES
THEO/0.2175,-0.215,0.305,-1,0,0
ACTL/0.2182,-0.215,0.305,-1,0,0
TARG/0.2175,-0.215,0.305,-1,0,0
ASSIGN/SLT_V5 = SLT_4.X-SLT_1.X
SLT_CPT2 =FEAT/POINT,RECT
THEO/0,-0.215,0.305,0,-1,0
ACTL/0.0005,-0.215,0.305,-0.0018643,-0.9999954,0.0024068
CONSTR/POINT,MID,SLT_1,SLT_4
ASSIGN/SLT_V6 = SLT_CPT2.X
ASSIGN/SLT_V7 = SLT_CPT2.Y
ASSIGN/SLT_V8 = SLT_CPT2.Z
F4 =GENERIC/CIRCLE,DEPENDENT,RECT,IN,$
NOM/XYZ,0,-0.215,0.305,$
MEAS/XYZ,SLT_V6,SLT_V7,SLT_V8,$
NOM/IJK,0,-1,0,$
MEAS/IJK,0,-1,0,$
DIAMETER/0.435,SLT_V5
A5 =ALIGNMENT/START,RECALL:A_C_D, LIST= YES
ALIGNMENT/TRANS,XAXIS,DAT_B1
ALIGNMENT/END
COMMENT/REPT,Width and position of .435 wide slot to -B- (2X, bottom then top)
DIM DIM_3= TRUE POSITION OF CIRCLE F3 UNITS=IN ,$
AX MEAS NOMINAL +TOL -TOL BONUS DEV OUTTOL
DF 0.4352 0.4350 0.0050 0.0050 0.0052 0.0002 0.0000 ----#----
D1 0.2322 0.2320 0.0005 0.0000 0.0002 CIRCLE DAT_B1 AT MMC
TP MMC 0.0000 0.0052 0.0000 0.0000 #--------
END OF DIMENSION DIM_3
A6 =ALIGNMENT/START,RECALL:A5, LIST= YES
ALIGNMENT/TRANS,XAXIS,DAT_B2
ALIGNMENT/END
DIM DIM_4= TRUE POSITION OF CIRCLE F4 UNITS=IN ,$
X 0.0006 0.0000 0.0006
DF 0.4354 0.4350 0.0050 0.0050 0.0054 0.0004 0.0000 ----#----
D1 0.2323 0.2320 0.0005 0.0000 0.0003 CIRCLE DAT_B2 AT MMC
TP MMC 0.0000 0.0054 0.0012 0.0000 -#-------
END OF DIMENSION DIM_4Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
by JacobMagI have a PCDMIS 4.2 with MR1 version. I believe that there is a flaw in the software which it does not allow to choose the appropriate modifier (M, R,...
Channel: PC-DMIS Vision
03-12-2010, 02:00 PM -
by JigneshI started using legacy dimension when Translation to z=o is not set at Datum-A where holes are located to find true posion of four holes mean true position...
02-26-2016, 10:36 PM -
by DeWain HodgeI'm programming several parts that have a true position of a width with an MMC modifier. I have no problem measuring either side of the feature and getting...
04-27-2007, 10:15 PM -
I was wondering if anyone else has seen this issue???? I go to tolerance a true position and it will show totally different then the basic's if i tolerance...
05-13-2009, 08:52 AM -
by GuestCan anyone tell me what the formula is for True Position? For whatever reason this engineer thinks that the true position should have a bilateral tolerance....
06-12-2008, 07:22 PM -
