Add angles from 1 probe to another.
  • Add angles from 1 probe to another.
    So i'm replacing a few probes with new build. These probes have a lot of angles on them and instead of manually adding all the angles from these probes to the new probe build, is there a way to just copy the angles from 1 probe to another?
    Not that I am aware of =/
      replacing, as in, you plan on using 1 probe file instead of 2 (or more)?
      If so, simply change the probe file name in each program that will be using the new probe file, then do a MARK USED, it will then add those angles to the file. Other than that... no dice.
        Yes correct Matthew and i did not think of that should work just fine. I do have a script that Ninjabadger gave me to change probe names in all programs.
        Although this seems like something that should have been added to PC DMIS.
