Have mutiple SPC directories within 1 program.
  • Have mutiple SPC directories within 1 program.
    So I have to write a macro CMM program where 1 program will be used to measure numerous different part numbers. Every part number is a little bit different that the other. My issue is data collection. I will be using QC.Calc to record data & report real time run charts at the CMM. I need to have a separate QCCALC file for each part #. How do I do this when I am only writing 1 CMM program. Usually your QCCALC file is named whatever your CMM program is named in the top left corner of the CMM program. I need to make that name changeable. Anyone have any idea????
    Will be using the newest version of PCDMIS
    Will be using QC.Calc real time for SPC collection.
    MIKE OXLONG
    I don't know about that.
    However I do believe that you could create one program with an operator comment, flow control, and File/IO commands to run one program, that in turn runs any program you want.
    Otherwise, you would have to use File/IO commands to rename the file to whatever it is you want.
    EDIT:
    E.g. Save it in a single directory, with a single name.
    Have a File/Copy command at the bottom to copy the created QC-Calc file to the new location with the new name
    Have a File/Delete command below that to delete the original, bogus file
      Probably create/execute a script that changes the name in the header based on input before executing the stats on command?
      how is the current stats output generate?
        here is the sample Code and Script
        C1         =COMMENT/INPUT,NO,FULL SCREEN=NO,
                    Ener Serial Number to Select Part.....
                                1.) 111111
                                2.) 222222
                                3.) 333333
                    SELECT/C1.INPUT
                      CASE/1
                        ASSIGN/PART_NUM="111111"
                        ASSIGN/PART_DES="XXXXXX"
                      END_CASE/
                      CASE/2
                        ASSIGN/PART_NUM="222222"
                        ASSIGN/PART_DES="YYYYYY"
                      END_CASE/
                      CASE/3
                        ASSIGN/PART_NUM="333333"
                        ASSIGN/PART_DES="ZZZZZZ"
                      END_CASE/
                    END_SELECT/
        Sub main()
        Dim Prg As Object
        Dim PartProgram As Object
        Set Prg = CreateObject("pcdlrn.application")
        Set PartProgram = Prg.activepartprogram
        Dim Cmds As Object
        Set Cmds = PartProgram.Commands
        Dim Cmd As Object
        '___________________________________________________
        Set partname = PartProgram.GetVariableValue("PART_DES")
        strpartname = partname.stringvalue
        PartProgram.partname   = strpartname
        Set Partnum = PartProgram.GetVariableValue("PART_NUM")
        strPartNum = PartNum.stringvalue
        PartProgram.SERIALNUMBER = strPartNum
        End Sub
        • BKulpa
          BKulpa commented
          Saw your script last week and thought it would be useful.
          Put into action this morning.
        I use the tracefield command in the code below to do this. You will have to change the file name where the red X's are. I have programs where there are 5 or more parts in the same program and just use this to toggle between them.
        TRACEFIELD/NO_DISPLAY,LIMIT=20 ; DBSWITCH : XXXXXX
