Good Morning
I am using a shank probe in a program and have adjusted the nominal depth of each hit by 1.5mm so that I can ensure the part will hit on the shank. My question is, what value do I use for the shank offset during calibration(1.5mm or 3.0mm)??? The shank probe is 1.5mm in diameter. Also looking at the calibration results (vectors) how do you determine what is acceptable.
Thanks
Scott
Thanks
Scott
