I have a part that has a bolt circle around a 1.21 hole. The hole is clocked to Y+ and the holes around my circle are -63°, -93°, 42°, 72°, 177°, 207° I have made 3d lines from the 6 holes to the center of my 1.21 hole and tried to measure an angle to Y+ which doesn't give me a believable angle. I also tried to get an angle from the circles to Y+ and also from line to line and can't get believable readings.
If I rotate my alignment Y+ matches up with my lines in the graphic display. How do you measure angles?
PC-DMIS CAD++4.0
PC-DMIS CAD++4.0
