Xactmeasure, Primary Datum as spatial but not origin
  • Xactmeasure, Primary Datum as spatial but not origin
    Is there any way to get Xactmeasure to use the primary datum to level to but not as the origin? I realize I can create an offset plane using the primary and either input a distance or choose a feature for the offset but wasn't sure if I could do it directly in Xact.
    And on that topic... how would you call out a primary datum on a drawing that is derived from 2 features, one being a top plane and the other being a hole as origin on the side of the part where the origin follows the hole location, not a basic distance from the plane?
    Hope that made sense.
    PC-DMIS 2015.1, SP10, CAD++
    Global 7/10/7, 5/5/5
    Renishaw PH10MQ, PH10M, TP200
    Max Go to the help file, and Read up on that there it explains it pretty good. You will have to choose Custom.
    • DJAMS
      DJAMS commented
      You know it isn't hard to get rid of all the highlighting before you screnshot, Kirby.
    • KIRBSTER269
      KIRBSTER269 commented
      DJAMS yeah, I leave at 4:00 and as you see posted that at 3:47, so I wasn't worried about making it pretty
    Thanks, Kirbster! I'll read up on it. Didn't realize I could create my own.
    Cheers! ice-cold-beer-2.jpg Have a great holiday!
      No love from the Demon. I am unable to choose certain combinations of features and degrees of freedom in the Custom DRF. For example, I have a plane, plane, cylinder. I want to level Z to the plane, rotate and origin to the second plane, and 2 origins on the cylinder. No go. Even if I put the cylinder as my secondary it will not allow it to be used as the Z origin. The help says all DOF left can be applied to the next datums. What gives?
      • KIRBSTER269
        I do have a question for ya. Is the cylinder perpendicular to G or is it Parallel?
      I believe you're exactly where you want to be. Provided that you're aligned/origined to the datum features.
      Look again at the last sentence of the paragraph beneath the graphic in the help file screenshot kirby posted. As soon as you uncheck a dof, it defaults to alignment origin, and no longer appears as a choice in the drf.
      I disagree strongly with this software design decision. I feel that all the dof's constrained by a datum should be listed after that datum. As it stands, the fcf shown on report will just cause a ton of explaining. I like your line of thinking much better.
        First of all don't try setting your origins according to your layout, and maybe work backwards. Your tertiary will only control X and Y. "Z" will only occupy the Primary or secondary. You need to look at it like your applying it to the part, not how you lay it on the table. Max Tasty
        also primary datum to be leveled to Z+ and secondary rotated X+ you got to follow the rules
          My apologies, Update, Z will work in any location of the FCF. All degrees must correspond with the layout. My first example was determined on how it was called out. If it can work it will work. Sorry
          • VinniUSMC
            VinniUSMC commented
            Do you mean that you cannot select Z anywhere in the FCF at all?
          • KIRBSTER269
            No. It's just a pain in the a_s_s to orientate. In order to pick the origins and constrainments. You have to free them up, but you also can't leave one blank. Which means that you have to occupy it with a constraint or origin which could effect the other callouts. It can be tricky as h_e_l_l It can be done it is just like a rubiks cube, trying to get the colors lined up. VinniUSMC
          • KIRBSTER269
            I think I'll just stick with having the customers fix their print, if I was to ever encounter something like that. Fighting with them seems way easier.
        • marcc
          Confused with Xactmeasure
          by marcc
          My alignment is:
          - level Y- and X,Z origin to cylinder
          - rotate X+ to plane
          - Y origin to circle
          Need to check position of CIR...
          10-10-2019, 12:08 PM
        • therunner
          Alignment Help
          by therunner
          I need to report the surface profile of a roller feature to Datums -ABC-. However, I am unsure how to make the proper alignment in regards to making a...
          05-03-2018, 11:21 AM
        • bubbagump
          coaxial alignment help
          by bubbagump
          How do you align a part that has datum A (plane in the z axis), datum B is a circle in the yz (left side of part, -x axis), datum C is a sphere in the...
          01-10-2012, 04:57 PM
        • Bob Pierce
          Alignment help
          by Bob Pierce
          I have never had to make an alignment such as the one in the attachment.
          Datum C is to be added and will be the axis of the 10MM screw hole on...
          03-05-2009, 02:31 PM
        • Mansukh
          Datums
          by Mansukh
          If DRF is ABC, then A always used for level, B always uesd for rotation and C always used for origin ? If DRF is BAC, then B for level, A for rotation...
          12-19-2016, 11:14 AM
