Autodev fol fil bol
  • Autodev fol fil bol
    The Purge with character limits.
    Automotive deviation letters, I=INBOARD, O=OUTBOARD, F=FOR, A=AFT, L=LOW, H=HIGH used to determine the feature from the car coordinate system.
    PC-Dmis V3.7 to 2011MR2 DatapageRT/Datapage+
    Global, Sheffield, Tracker, Leitz, PMM
    Never confuse movement with action!
      Actually, the Help can many times be very helpful. Almost everything is described there, but it can be very tricky to find it.
      In the current case you saw the word AUTODEV on the report, and wondered what it was. Unfortunately, the AUTODEV word is not written as text anywhere in the Help, it's only there in a picture, which means even a complete word search will not find it :-(
      Now when we know it's called "Automotive deviation letters", it's easy to find the Help page:
        Interesting. All dim's are showing up in red color including those in spec.
        sigpicIt's corona time!
        • Mike Ruff
          Mike Ruff commented
          I noticed that too. cowrevenge, you should go into Edit>Grahic Display Window>Edit Dimension Color and change your colors so good dims aren't red
