Questions Regarding a 45° Fixed Probe
  • Questions Regarding a 45° Fixed Probe
    Hello!
    Running PC-DMIS 2013 MR1 SP5 With a TP200 Tactile/Vision System
    So I've got this probe here; a 45° on a knuckle (I believe is the term)
    It does not rotate, it's fixed at 45°.
    Well... I recently had a crash and destroyed the TP200 module ($$$) which has been replaced. [If that's correct; the piece with the red light!]
    This module is, as you can imagine, clocked slightly differently than the last one (I had to reload all of my probes into the probe changer manual/DCC or they would not seat correctly)
    Which was easy.
    Well now I've got this probe! It's swayed!
    With the old module, the 45° probe was **** near (if not) perfectly in line with Y- (So it faces 45° between Z- and Y-)
    With the new module, it's tilted 45° towards X- (So now it's 45° between Z- and Y-, AND 45° between Y- and X-!)
    I'm curious on if that matters.
    Ideally I'd just unscrew it a little, make the adjustment, lock it back in and calibrate.
    I'd like to know how precisely I need to have it aligned, I guess? I think the fixed 45° won't change, because of the knuckle, I just need to change its X rotation.
    Will "eyeballing" (e.g. not using an indicator) to "level" the probe to Y- be fine? As in there will be negligable uncertainty from doing so, or should I call Hex-a-Tech?
    Hmm... All looks like word soup to me. Hopefully you guys understand what I'm looking for. Per my understanding (of star probes) it doesn't matter a whole lot (as long as it's not like crazy tilted), but I don't use this probe (literally ever except today, though I'd like to use it more) and I want to make sure my setup is correct.
    We're due for calibration pretty soon, so someone'll be out here I can defer all my questions to, eventually
    Hoping y'all have some advice
    Eyeballing is usually fine.
    What you need to worry about is will the probe shank when checking your part.
    If the ball is close to the same diameter as the shank it COULD shank on the sphere if your eyeball is not so good, but with most probes this isn't likely. More likely you'll stick the probe in a hole too deep for your eyeball error and shank on the part.
    Pull the knuckle off the extension/module.
    Bring the extension/module down to a 1-2-3 block or the plate.
    Lock off X travel on the jog box.
    Make a mark with a sharpie on the block/table.
    Move in ONLY X one way or the other.
    Make another mark.
    Connect the marks with a scale so you have a line.
    Move the head up but keep Y locked.
    Put the knuckle on the extension/probe.
    Rotate the ruby so it is on top of the line, remember keep Y locked, you can move X and Z for this.
    Tighten the knuckle.
    This will be extremely close to correct and minimize your chance of shanking.
    This is also what you do with a star, putting the tip that is straight down in one of the holes on the 1-2-3 block.
    • InspectorJester
      InspectorJester commented
      My jogbox has none of these.
      I have a big black plastic box, with 4 buttons; E-Stop, Rotation, one that does literally nothing (I read the manual) and one that makes a clicking sound when I press it.
      Thanks though!
    • InspectorJester
      Maybe not music, but Morse is pretty fun :P
    • Caemgen
      Caemgen commented
      Sorry for slow reply on this, but you can use the bottom ribbon bar of pcdmis with the XYZ for a DRO and after you move along X to the second point for drawing a lline, move Y REALLY slow to the same location it was before.
      Be sure when doing this you are in machine coordinates (STARTUP) so you are using numbers square to machine axes. Much bigger pain, but I'm hoping you have a speed control knob on your box.
    This post points out the design flaw, IMO, of the TP200 mounting process. We have 3 machines that all have TP200's and we can swap probes between all machine except for any stars & angled/L probes. It's a pain having to create multiple identical probes for different machines. Poor design, but definitely a money maker on selling more probes.
    PC-DMIS 2015.1, SP10, CAD++
    Global 7/10/7, 5/5/5
    Renishaw PH10MQ, PH10M, TP200
    • InspectorJester
      I believe it's due to the inherent "clocking" of the TP200 module itself. The 3 shapes won't line up perfectly from machine to machine.
      Still, I don't see why it couldn't be the same probe, just calibrated each time it switches machines (which you should do anyway...)
      Also curious
    You can use the same probes if you position your part differently on each machine. But an L probe built in +X direction on one machine will not be in +X direction on the next, due to the TP200 module being threaded differently on each one, so it will shank out. They don't all screw in to the same position. So you either have to position the part differently on each machine to compensate or create individual probes.for each machine.
    • InspectorJester
      My question follows the thought that you would just adjust the probe to match the machines +X direction and calibrate using the same probe.
      Is this not the case?
    Not necessarily. Adjusting the angle of the probes from machine to machine takes time because there is no calculable angular reference from TP200 to TP200. You have to put it on the TP200, make adjustments, check it against the machine axis, and do that until it's square. We also have probes that are built very specific to certain parts that fit into very tight spaces at different angles. Breaking those down is not cost efficient. It's cheaper to either run the same parts on the same machine all the time or build separate probes for each machine.
    • InspectorJester
      Makes sense! I only have 1 machine, so I'm naive to the tribulations of multiple!
      +1
      EDIT: I think I was confused; I had originally thought you were suggesting using the same phsical probe, but defining it 3 seperate times, one for each machine. I now understand you were referencing 3 seperate probes altogether
    • InspectorJester
      cowrevenge I'm interpreting it as there are 3 of the same probe builds (e.g. 3 different TP200_1x10's), one for each machine
  • IZAKK
    Star Probe Alignment
    by IZAKK
    I have never used a star probe before and I am having trouble. I am using a 5way and I’m only using connection #3, which I have loaded a1mmby10mm styli...
    10-22-2009, 04:07 PM
  • BIGWIG7
    Calibrating Multiple Probes Error
    by BIGWIG7
    big program that requires 3-4 (more or less) different probe builds and tips.
    calibrate all the probes only to find out half way through...
    04-13-2015, 05:54 PM
  • cbrown
    Star Probe Setup
    by cbrown
    First off, I'm really new at this and the guy that normally does the CMM work here is out for the week. My problem is that I was using a 3-tip star probe...
    09-10-2014, 03:05 PM
  • DmisDave
    Changing probe in a program?
    by DmisDave
    I have a TP200 and two modules with different probes attached. I would like to change probes in the program. It appears that I can use a Load Probe command...
    05-14-2010, 01:29 PM
  • Siren
    Probe Issues!
    by Siren
    Hi everyone,
    I have a Leitz with 4 star probes, they work very well and I did not have problems about it. The problem I have is when I...
    06-22-2011, 11:20 AM
