Report Comments
  • Report Comments
    I'm currently using v3.7 MR3. I have generated a program with Report Comments before each reported dimension. When I toggle from the Command Window to the Report Window, the comment changes.
    Example: Command Window
    .120 +/- .030 Diameter
    True Position | .010 (m) |A|B|C
    Report Window
    -.120
    Any Ideas?
    Put it "in quotes"
      Report Window
      -.120
      Any Ideas?
      I know this is not an answer, but why you want a comment
      similar to what CMM reports? 0.120 +/- 0.030.
      sigpicIt's corona time!
        Originally posted by craiger_ny View Post
        Put it "in quotes"
        It sees it as math, huh? that +/- must really wreak havoc to come up with -.120
          Can you post the code? I just entered a comment/report and it looks fine...
                      COMMENT/REPT,.120 +/- .030 Diameter
            DIM LOC OF PLANE 10 +,- .030 AT A3= LOCATION OF PLANE PLN10 UNITS=IN ,$
            GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH
            Z 1.350 0.030 0.030 1.350 0.000 0.000 ----#----
            END OF DIMENSION LOC OF PLANE 10 +,- .030 AT A3
            Can you just add it to your dim statement
              Did you flip it into report mode?
              edit: I just tried it too john and it worked ok also. It must one of those random things. I had something similar happen before, though.
                I'm just wondering if you can use ± (that is alt+241) instead of +/-. I bet it won't think ± is a math function.
                • cmm43
                  Output Report
                  by cmm43
                  I am using PC-DMIS CAD++ NC 4.2 mr1
                  Having issues with features being measured and toleranced and sent to the report out put window. When...
                  10-06-2008, 01:59 PM
                • Jignesh
                  Not showing in Report window
                  by Jignesh
                  I calculated angle measurement in Edit window, but it is not showing in Report window eventhough I refreshed the Report window.
                  03-15-2018, 03:35 PM
                • Brad Day
                  Report Window in Inspect 3.2
                  by Brad Day
                  Am I missing something is it possible to simply place the PCDMIS report window ( as the program runs ) in the Inspect Report without having to create...
                  07-26-2018, 12:23 PM
                • #2#
                  Report Comments Don't Show
                  by #2#
                  I have not really had much use for report comments in the past. I do now. I put a couple in my program but they do not show up on the report. How do I...
                  04-05-2007, 09:34 AM
                • cmm43
                  Report Output
                  by cmm43
                  Anyone please reply.
                  I am currently using PC-DMIS 4.2 mr1.
                  Has anyone experienced problems with true position of holes not reporting...
                  10-06-2008, 01:04 PM
