Good morning all, I have an inherited fixture, built to opposite side of material, my company normally has fixtures build to design side of material. Is it standard to build the fixture using the min. material thickness, if it required to be built to opposite side of material?
I checked the nets using a nominal material thickness offset, but it was out. Then I checked the same points using the min. material thickness and they are good. Thanks in advance.
