Measure-spher
As an Autosphere. You will need to adjust the start stop angles and the angle vectors to control where the hits fall.
Or if you feel up to crunching the trig for vectors you could take vector points and construct a sphere from them
Either of these methods will work well if you have enough of the spherical radius and/or it is big enough. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
The vectors for 45 degrees are +/- .7071068. You'll need to control these according to the axis that the sphere is tipped along. If it's tipped in the positive direction of the axis then the vector will be positive. If it's tipped away from the positive axis direction then the vector will be negative. You can mix positive and negative as well. If the sphere is tipped along the positive X and negative Y the vectors will be .7071068 for I and - .7071068 for J. You may have to play with it to get them correct.
Bill
by PowerJunkieHave my vectors been wrong all along? I know I'm going to catch **** for asking this but oh well here goes...
My cal sphere sits on the...-
04-06-2009, 11:45 AM -
by claudeI am just learning PCDMIS and I have a question about the Vector directions. Is the IJK different in different working planes?
Thanks,...-
08-05-2007, 11:59 PM -
by CookieHey,
I have not used the sphere feature beforeand I must be getting my vectors messed up.
I have attached a file showing...-
01-14-2010, 11:29 AM -
In relation to my post a few posts down........Rob Knoerlein-circular part with 8 legs.. If I am rotated 90/135 and tracking to hit a feature ( in this...
07-08-2008, 01:28 PM -
by GuestCan anyone help me figure out what I am doing wrong. I click on cad to measure a sphere (out) and try to measure it and it crashes. What am I not doing...
09-10-2008, 09:09 AM -
