I need to capture a surface profile of an ID. To measure this feature I took a bunch of points and constructed a line. I also measured the radius for a separate drawing call out. When dimensioning, it will not let me select the constructed line or the radius that was measured but, it would let me select all the points I took. My question is, by selecting all of the points when building the feature frame, does it automatically construct a theoretical line and use that to check the profile?
Programming Surface Profile
TK +1
To add to that... when you construct features from points it uses a fitting algorithm to construct the feature, which will usually yield a different profile result than profiling the points as a set or individually.PC-DMIS 2015.1, SP10, CAD++
Global 7/10/7, 5/5/5
Renishaw PH10MQ, PH10M, TP200
- 3 likes
Better is a relative term. If you're checking a discrete profile of a surface then I'd use points or a set because it will usually represent the actual surface deviation better. Once you start constructing features you're introducing an equation that can alter the deviation and location based on how it's solved by the program and what fitting algorithm you choose, i.e. LSQ, MIC, MCC, etc.
This is the explanation I was looking for!
+1
by hertangelHello.
Can someone help me with ptofile ?? Say, i have total of 16 points. on Z axis .what its the next step how do a group all the points and...-
11-18-2011, 09:18 AM -
by keegoSee attached. What is the best way to measure the profile callout with PC-Dmis? A circle? Scan? Constructed Curve? Constructed Line? I've tried...
11-10-2009, 12:05 PM -
Have a quick question on how PC-DMIS calculates the surface profile dimension. Im am trying to do the profile of a vibra-weld rib on a part, the print...
02-20-2015, 01:11 PM -
by optonGents,
I inspected profile on a part in several sections (cylindrical part) as a Measure Set (16 hits in every section) and tolerated in rel to...-
12-14-2018, 12:54 PM -
by wcdr99Trying to understand how to compile the data to get profile of a surface using version 3.7-2 tried just opening profile of a surface and recalling the...
08-17-2010, 06:14 PM -
