Whodini
Whodini
On the graphic screen when you right click, you'll have a popup box with a few options about the labels, I choose the one "I Think" hide dim info and now when I right click my screen flashes and it gives me no popup box to choose nothing. Anybody knows because I don't where to reset this option.
sigpicTags: None
I think you HAVE to right-click on a label that is already showing for that to pop up. If no label are showing, then it will not work. Place your cursor in the edit window AFTER at least 1 feature, then edit feature appearance, turn on the labels.sigpic
Matt's way works. What I do if I accidentally hide all features (why would you want to do this btw?) is just trigger the probe and hit done. It inserts a point. Then, I can right click - show all features. Once all my features and labels re-appear, I delete that point.
Originally posted by Goodluck View PostMatt's way works. What I do if I accidentally hide all features (why would you want to do this btw?) is just trigger the probe and hit done. It inserts a point. Then, I can right click - show all features. Once all my features and labels re-appear, I delete that point.
Oh, I will hide all features quite often for several reasons, I do it quite often. HOWEVER, recalling a saved view (but NOT inserting it into the program) will also bring them back.sigpic
Originally posted by Matthew D. Hoedeman View PostWOAH! That would suckulate BIG time if you forgot to delete that added point, woulnd't it?
I suppose it would be safer to insert a created feature. That would show up on the graphics display window and then there would be a label to right click on. Also, if I forgot to delete, it wouldn't cause a crash.
That method is just faster for me than looking through the menus to find where to edit the feature appearance.
Originally posted by Goodluck View PostYes, it could. Luckily, I haven't done that yet and as that feature has not been executed, it is still un-marked and easy to find.
That method is just faster for me than looking through the menus to find where to edit the feature appearance.sigpic
Originally posted by Matthew D. Hoedeman View PostCan you say, "Custom Tool Bars"? I just clikc on an icon at the top of the screen, mark a feature, turn on label, and good to go (or, use the recall saved view).
Originally posted by Goodluck View PostMatt's way works. What I do if I accidentally hide all features (why would you want to do this btw?) is just trigger the probe and hit done. It inserts a point. Then, I can right click - show all features. Once all my features and labels re-appear, I delete that point.sigpic
PCDMIS 2012
Windows Office XP
Originally posted by Goodluck View PostYeah, that is a good idea. I try to keep my toolbars to a minimum as I only have a wee-little monitor and like my graphics display window as large as possible.sigpic
Originally posted by rangerboat72 View PostWhy not use: EDIT==> GRAPHICS DISPLAY WINDOW==> FEATURE APPEARANCE?
Originally posted by Matthew D. Hoedeman View PostWhat, you don't have a SAMSUNG SyncMaster 204T monitor and a ViewSonic Professional Series P95f+ like I do all running at once? But, I only have 2 bars of toolbars at the top of my screen. 90% of the stuff I use shows in my customer toolbars, the other 10% is stuff I use, but rarely, so I didn't put it in the custom bars (hic!).
Originally posted by Goodluck View PostThat works but I can never remember where to find it and so it is quicker for me to do my method than go-a-searching.
I wish I could convince my boss to buy me a bigger monitor or a video card which supports two monitors and another monitor. As it is, I've got a 15" CRT that was probably new before 1990. It is so old that the case on it is that yellowish-brown color.sigpic
I'm with you on this one .. I often have programs with hundreds of points on them. I find it easier to block out everything and just turn on the labels I am Working on.
Originally posted by rangerboat72 View PostWhy not use: EDIT==> GRAPHICS DISPLAY WINDOW==> FEATURE APPEARANCE?Tolerance challenged ... Living in the world of unseen lines.
What only one monitor?Last edited by kmcmm; 03-21-2007, 04:52 PM.Kevin
How do I make the labels in the graphics view come back after I hide them?
09-03-2008, 05:22 PM -
by Joe ArnoldOnce a feature label is hidden how do you show the label again?
05-27-2008, 03:17 PM -
by johnboyI received a program from a customer and the labels in the graphics window seem to be 'auto-arranging', positoned around the perimeter of the window....
09-11-2006, 01:01 PM -
by CAD_FanaticHello...I am wanting to keep my labels pushed out to the parameters of the graphics window. I can place them there with auto label placement but they...
02-09-2011, 01:12 PM -
by 57shrimpIs there a way I can show a group of ID labels say pnt20 to pnt50.
Or am I stuck with show/hide based on view or all ?
How can...-
12-15-2016, 06:43 PM -
