Loading 2 probe files
  • Loading 2 probe files
    I have just finished writing a program which requires 2 Probe files to be loaded(access and don't have a dual sphere for calibration purposes).When i run the program ,i need to sit by the machine ,as every time it gets to the point in the programme where the probes are loaded,it ask to LOAD PRODE OK.Is it possible to allow the programme to run without this pause/prompt happening.I am running 3.7++cad on a TYPHOON 201508.I hope this explains my problem.
    It's only a mistake if somebody else finds it!
    if you are manually changing the probe module, then you will have to live with this.
    if you have a probe rack then there may be a way around it. I don't know as I don't have one.
    there are those members on the forum that do have a rack and will reply probably in the morning.
    good luck
    bob
    Starrett RGDC 4028-24 :alien:
      I am not changing the probe module or any of the tips,I need the 2nd probe file for the access to 2 points on the part.I don't have a rack for the tips.Is it possible to load the 2 probe files at the start of the programme?
        I don't get it. Are you talking about single probes or a star config.?
        How can you load 2 probes at the same time?
        Maybe I don't get the whole picture.
        sigpicIt's corona time!
          not sure I see it either.....a bit hazy here...must be the weather
          Are you using multiple positions of the same probe tip?
          If so they should all be in one probe file...no need to load the file a second time
            I am using a star probe set up.the reason why i need 2 probe files is.
            1.I am mesuring 12 points on the front side of the part which i can access using tips 1 & 5 on the star probe.these can be calibrated with the sphere 0,-1,0.
            2.I then need the probe at 105/-90,tip 5, for the 2 points on the rear of the part,the sphere needs to be 0,1,0.
            3.I don't have a duel sphere to calibrated the required angles to only have 1 probe file.
            P.S see attachment on 1st post for angles i require.
            As far as the weather goes ,its not abit hazy, its very foggy at the minute!
              If you don't need to change the module nor the tip, then remove the line (2nd LOAD PROBE) from your program and just leave the probe angle change.
              That way it will run with no stops.
              Careful! I am assuming both probes are part of the same star config. and have been calibrated.
              Also, make sure probe is clear prior to rotation (avoid crashes).
              Hope that's what you're looking for.
              • moril
                losing probe files 2011 mr1
                by moril
                Recently changed to 2011 MR1 on the advise of Hexagon due to our off-line stations losing entire program files when they crashed, this has now stopped...
                04-03-2012, 04:31 AM
              • WolfMan
                Cimcore calibration
                by WolfMan
                So, I have calibrated using a reference Sphere all 3 probes, 15mm, 3mm, 4mm.
                Inside my program I have 3 probe files, 3mm_93L, 4mm_94_L and...
                05-16-2016, 11:21 AM
              • ag162
                Probe File
                by ag162
                Good Morning,
                I have a situation at my new place of employment. My account was created and when I open pc dmis (which is sharing the c drive),...
                05-08-2006, 07:47 AM
              • tinabeth
                probe changes in programs
                by tinabeth
                Using 4.1 PCDMIS with a tp200 with magnetic modular.
                I'm trying to understand more about changing probes in programs?
                I have probe files...
                10-11-2009, 04:44 PM
              • dennisgilpin
                Probe files restore
                by dennisgilpin
                Hey there, I need info on how to restore my probe files. I re installed 2011 MR 1, I have the probe files saved but don't know how to get them back into...
                11-25-2013, 04:12 PM
