Const of circle from sphere ??
  • Const of circle from sphere ??
    If given a particular diameter, and asked for the height, how would you do that ? I have no problem with doing a cone like this, thats easy.
    I need to pierce a sphere with a given diamter in order to output the height...
    Any of you genuises got any good ideas, I am out of them ???
    Jim Jewell
    Leave it for night shift?
      Height from centerline = SQR((SphereRadius^2)-((CircleDiameter/2)^2))
        F1 is the measured sphere.
        Change the height of the generic plane until you reach your given diameter.
        F1 =GENERIC/SPHERE,DEPENDENT,RECT,IN,$
        NOM/XYZ,0,0,0,$
        MEAS/XYZ,0,0,0,$
        NOM/IJK,0,0,1,$
        MEAS/IJK,0,0,1,$
        DIAMETER/50,50
        F2 =GENERIC/PLANE,DEPENDENT,RECT,$
        NOM/XYZ,0,0,0,$
        MEAS/XYZ,0,0,10,$
        NOM/IJK,0,0,1,$
        MEAS/IJK,0,0,1
        KR1 =FEAT/CIRCLE,RECT,OUT
        THEO/0,0,0,0,0,1,50
        ACTL/0,0,10,0,0,1,45.826
        CONSTR/CIRCLE,INTOF,F1,F2
        Sorry for my bad english.
          Here's another idea (besides leaving it for night shift):
          1) Construct a point at the center of the sphere.
          2) Construct 4 offset points equal to the radius you want (in X+, X-, Y+, Y-)
          3) Construct 2 sets of offset points of the 4 original offset points, 20 and 40mm (actual numbers, your choice) below the original points
          4) Construct a cylinder from the 12 points
          5) Intersect the cylinder with the sphere to make the circle you are looking for.
          I am not sure if this will work, but I do know if I were to do this in my cad software, I would come up with the circle you are looking for. You may have to change the up/down offset points to above instead of below to get the intersection you want.
            Originally posted by cmmguy View Post
            Height from centerline of the sphere= SQRT((SphereRadius^2)-((CircleDiameter/2)^2))
            This is correct. I checked the math. I just added the "T" above to make sure you read that as "square root".
            I believe you would need to do an assignment and then create a generic feature with that as the x,y or z location (assuming the sphere center is 0,0,0). Then dimension the generic feature.
            Last edited by #2#; 03-20-2007, 01:51 PM. Reason: Clarify that the sphere center must be 0 to set x,y or z correctly in the generic feature.
              I believe you would need to do an assignment and then create a generic feature with that as the x,y or z location. Then dimension the generic feature.
              Thanks for the cleanup, double check, and explanation of how to apply it.
                No problem, I trusted you were correct but I like to work through it myself to make sure I fully understand how to get there. I won't remember the formula but I will, for some reason, remember how to figure it out - which I can try to explain if anyone is interested.
                  Thanks for the formula. Tried it , but haven't had time to really understand it just yet. I kinda figured it was SQRT....Tnx.
                  Update, got it to work properly, works great !
                  Tnx Again !
                  Jim Jewell
