Subroutine help
  • Subroutine help
    hello all,
    I am needing help with subroutines below is the list of code we are using and what we want to do is save the reports to a certain folder when the program is done running. I am having problems with the naming of the program, because we would like to use the system date and time in the subroutine, but it changes the subroutines letters to capital letters and pc-dmis wont read them?
    here is the code...
    PRINT_ID =COMMENT/INPUT,NO,FULL SCREEN=NO,
    PRINT ID
    INSPECTOR =COMMENT/INPUT,YES,FULL SCREEN=NO,
    OPERATOR:
    SHOP_ORDER =COMMENT/INPUT,YES,FULL SCREEN=NO,
    WORK ORDER:
    NUMBER_RAN =COMMENT/INPUT,YES,FULL SCREEN=NO,
    SINK:
    ASSIGN/PRINT=PRINT_ID.INPUT
    ASSIGN/WO=SHOP_ORDER.INPUT
    ASSIGN/STRINGDAY=SYSTEMDATE("ddd")
    ASSIGN/INTDAY=SYSTEMDATE("d")
    ASSIGN/MONTH=SYSTEMDATE("MMM")
    ASSIGN/YEAR=SYSTEMDATE("yyyy")
    ASSIGN/TIME=SYSTEMTIME("hh'_'mm'_'ss")
    ASSIGN/DATE_STAMP= STRINGDAY + "_" + MONTH + "_" + INTDAY + "_" + TIME + "_" + YEAR +"
    ASSIGN/WORK_DIR_ST="Y:\Brenco Reports"
    ASSIGN/MAIN=WORK_DIR_ST + "\" + PRINT + "
    ASSIGN/FILE_NAME=MAIN + "\" + PRINT + "_" + WO + "_" + DATE_STAMP + ".pdf"
    FOR THIS TO WORK YOU WILL HAVE TO CHANGE YOUR SEARCH PATH OF SUBROUTINES
    TO THIS Y:\Subroutine\
    THE FOLLOWING LINE OF CODE IS A SUBROUTINE
    MAKE SURE YOU ARE AT THE END OF THE PROGRAM JUST LIKE THE OLD SCRIPT
    YOU MUST GO INSERT, FLOW CONTROL COMMAND CALL SUB
    A WINDOW WILL OPEN AND THEN CLICK SELECT SUBROUTINE
    FIND THIS PROGRAM NAME, SUBROUTINE_GLOBAL, MAKE SURE THERE ARE NO SYMBOLS AFTER PROGRAM NAME
    ONCE YOU HAVE THE CORRECT ONE SELECTED CLICK OK THEN OK
    SUBROUTINE/SCRIPT-RINGROLL,
    PRINT = PRINT_ID.INPUT : ,
    WO = SHOP_ORDER.INPUT : ,
    STRINGDAY = SYSTEMDATE("DDD") : ,
    INTDAY = SYSTEMDATE("D") : ,
    MONTH = SYSTEMDATE("MMM") : ,
    YEAR = SYSTEMDATE("YYYY") : ,
    TIME = SYSTEMTIME("HH'_'MM'_'SS") : ,
    DATE_STAMP = STRINGDAY + "_" + MONTH + "_" + INTDAY + "_" + TIME + "_" + YEAR +" : ,
    WORK_DIR_ST = "Y:\BRENCO REPORTS" : ,
    MAIN = WORK_DIR_ST + "\" + PRINT + " : ,
    FILE_NAME = MAIN + "\" + PRINT + "_" + WO + "_" + DATE_STAMP + ".PDF" : ,
    PRINT_PATH = MAIN + "\" + PRINT + "_" + WO + "_" + DATE_STAMP + " : ,
    ASSIGN/DISPLAY_REPORT="C:\Program Files\Adobe\Acrobat Reader DC\Reader\AcroRd32.EXE" + " " + PRINTPATH
    PRINT/REPORT,EXEC MODE=END,$
    TO_FILE=ON,OVERWRITE=FILE_NAME,AUTO OPEN REPORT=OFF,$
    TO_PRINTER=OFF,COPIES=1,$
    TO_EXCEL_OUTPUT=OFF,
    EXTERNALCOMMAND/DISPLAY ; DISPLAY_REPORT
    ENDSUB/
    For some reason, it changes the ("ddd") to ("DDD") and all of the other lower case letters?
    What is PRINTPATH? I think this might be your issue, more than caps in the date codes.
    You have an assignment PRINT_PATH, but I don't think it belongs with the script line locating the pdf viewer... Right?
      I copied most of the subroutine from someone on the forums a couple of years ago and I have just made mods to it when we needed to. I assume the PRINTPATH line is there to pop the report up on the screen when the program gets done running? everything works with the script except the naming and it doesn't pop up, because the naming is not working.
      this is how the program is named when done running "5109_94900-000_DDD_Apr_D_YYYY_13_MM_SS" it should be named "5109_94900-000_Tue_Apr_3_2018_13_12_35"
        PRINTPATH is most likely supposed to be a variable that you need to assign that path to.
        PC-DMIS 2016.0 SP8
        Jeff
          Try these changes.
          ASSIGN/DATE_STAMP=STRINGDAY+"_"+MONTH+"_"+INTDAY+"_"+TIME+"_"+YEAR
          ASSIGN/MAIN=WORK_DIR_ST+"\\"+PRINT
          ASSIGN/FILE_NAME=MAIN+"\\"+PRINT+"_"+WO+"_"+DATE_STAMP+".PDF"
          or
          ASSIGN/DATE_STAMP=SYSTEMDATE("ddd")+"_"+SYSTEMDATE("MMM")+"_"+SYSTEMDATE("d")+"_"+SYSTEMTIME("hh'_'mm'_'ss")+"_"+SYSTEMDATE("yyyy")
          ASSIGN/FILE_NAME="Y:\Brenco Reports"+"\\"+PRINT_ID.INPUT+"_"+SHOP_ORDER.INPUT+"_"+DATE_STAMP+".PDF"
          Does this look right to you? Y:\Brenco Reports\5109_949000-000_Tue_Apr_0_03_35_49_2018.PDF
          In your part program:
                      Print ID
          INSPECTOR  =COMMENT/INPUT,NO,FULL SCREEN=NO,
                      Operator:
          SHOP_ORDER =COMMENT/INPUT,NO,FULL SCREEN=NO,
                      Work Order:
          NUMBER_RAN =COMMENT/INPUT,NO,FULL SCREEN=NO,
                      Sink:
                      FILE_NAME
                       At the END of Program insert a CALLSUB and pass your variable FILE_NAME
                                                 **************USE YOUR OWN PATH BELOW**************
          CS1        =CALLSUB/SCRIPT_RINGROLL,C:\Users\Public\Documents\WAI\PC-DMIS\2015.1\Subroutines\SubRoutineLibrary.PRG:FILE_NAME,,
          Your SUBROUTINE:
          SUBROUTINE/SCRIPT_RINGROLL,
                          FILE_NAME =  : ,
                        REPORT_THEORETICALS=NONE,REPORT_FEATURE_WITH_DIMENSIONS=NO,$
                      ENDSUB/
                      ASSIGN/DISPLAY_REPORT="C:\Program Files\Adobe\Acrobat Reader DC\Reader\AcroRd32.EXE" + " " + FILE_NAME
                      EXTERNALCOMMAND/NO_DISPLAY, NO_WAIT ; FILE_NAME
          Hope it works!
          PcDmis 2015.1 SP10 CAD++
          Global 7-10-7 DC800S
            wfcmm did you try it?
            • wfcmm
              wfcmm commented
              I am trying it this morning...I started making changes yesterday and had some "hot" projects to get done....I will be sure to let you know how it works.....Thanks for the help, so far
            • wfcmm
              wfcmm commented
              it doesn't work for me Kp61dude!....the report goes in the right path, folder etc.....but it doesn't get named right for some reason.......... the report name is
              "5109_94900-000_0" and should be "5109_94900-000_Tue_Apr_3_2018_13_12_35"....the date and time is coming up at -0-
              I did find I put the year and time in the wrong places and changed those around lol.
            Did you try:
            Instead of:
            actually did you try everything from the second example, after 'or', on post #5? Or what exactly did you change?
            • wfcmm
              wfcmm commented
              yea I did..........
              this is my subroutine:
              PRINT ID
              OPERATOR:
              WORK ORDER:
              SINK:
              ASSIGN/DATE_STAMP=SYSTEMDATE("ddd")+"_"+SYSTEMDATE("MMM") +"_"+SYSTEMDATE("d")+"_"+SYSTEMDATE("yyyy")+"_"+SY STEMTIME("hh'_'mm'_'ss")
              ASSIGN/FILE_NAME="Y:\Brenco Reports"+"\"+PRINT_ID.INPUT+"\"+PRINT_ID.INPUT+"_" +SHOP_ORDER.INPUT+"_"+DATE_STAMP+".PDF"
              FILE_NAME = "Y:\BRENCO REPORTS"+"\"+PRINT_ID.INPUT+"\"+PRINT_ID.INPUT+"_" +SHOP_ORDER.INPUT+"_"+DATE_STAMP+".PDF" : ,
              ENDSUB/
              this is what I have for my PP:
              at the beginning of the program:
              PRINT ID
              OPERATOR:
              WORK ORDER:
              SINK:
              at the end of the program:
              CS1 =CALLSUB/SCRIPT-RINGROLL,Y:\Subroutine\chuck2.PRG:,,
              Sorry for the wall of text
            I've had problems with naming files correctly as well. What helped me was saving them as a completely generic name and then, using some FILE IO commands, copying it to the correct location with the correct name (set as a variable) and deleting the default copy.
              yea I did..........
              PRINT ID
              OPERATOR:
              WORK ORDER:
              SINK:
              ASSIGN/DATE_STAMP=SYSTEMDATE("ddd")+"_"+SYSTEMDATE("MMM") +"_"+SYSTEMDATE("d")+"_"+SYSTEMDATE("yyyy")+"_" +SY STEMTIME("hh'_'mm'_'ss")
              ASSIGN/FILE_NAME="Y:\Brenco Reports"+""+PRINT_ID.INPUT+""+PRINT_ID.INPUT+"_" +SHOP_ORDER.INPUT+"_"+DATE_STAMP+".PDF"
              FILE_NAME = "Y:\BRENCO REPORTS"+""+PRINT_ID.INPUT+""+PRINT_ID.INPUT+"_" +SHOP_ORDER.INPUT+"_"+DATE_STAMP+".PDF" : ,
              ENDSUB/
              PRINT ID
              OPERATOR:
              WORK ORDER:
              SINK:
              CS1 =CALLSUB/SCRIPT-RINGROLL,Y:\Subroutine\chuck2.PRG:,FILE_NAME,
              Add the RED. Delete Green from Part Program.
              Delete ORANGE from your Subroutine.
              I doubt it but in case you are...let me know if you are color blind.
              • wfcmm
                wfcmm commented
                I did exactly what you had on here Kp61dude! and I still get the same "5109_94490-000_0"....it works when you hover over the scripts, but when it gets done running it puts the report in the right path, pc-dmis doesn't seem to like the date.
              Welp, I tried...
