Anyone tell me how to use the symmetry dimension tool
Have a part with 3 holes and 2 angular faces, see attached sketch.
I have created an alignment between holes 1 & 2 and placed the datum in hole 3.
I have measured a plane on sides A & B then created an alignment plane through the Y axis, this I called datum C. My Drawing calls for the Symmetry of the two angled faces to 0.2mm about C but I cannot get the correct answer?
The output is always zero & as a double check I have intersected the two side planes to generate a point that shows 0.011 off centre (0.022 symmetry?).
Help Guys Please??????
Sample code bellow
PLN2_BASE =FEAT/PLANE,RECT,TRIANGLE
THEO/25.407,-15.099,-33,0,0,-1
ACTL/25.407,-15.101,-33.049,0.0001184,0.0001586,-1
CONSTR/PLANE,BF,PNT1,PNT2,PNT17,PNT18,,
OUTLIER_REMOVAL/OFF,3
FILTER/OFF,WAVELENGTH=0
A4 =ALIGNMENT/START,RECALL:CAD=PART,LIST=YES
ALIGNMENT/LEVEL,ZMINUS,PLN2_BASE
ALIGNMENT/ROTATE_CIRCLE,XPLUS,TO,,AND,,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,CIR4_CTR-HOLE_TOP
ALIGNMENT/TRANS,YAXIS,CIR4_CTR-HOLE_TOP
ALIGNMENT/TRANS,ZAXIS,PLN2_BASE
ALIGNMENT/END
PLN3_RIGHT_SIDE=FEAT/PLANE,RECT,TRIANGLE
THEO/64.884,15.016,14.947,0.9543178,-0.2987935,0.0000012
ACTL/65.194,14.929,14.99,0.9539854,-0.299852,0.0007343
CONSTR/PLANE,BF,PNT3,PNT4,PNT5,PNT7,PNT8,PNT9,PNT6,,
PLN4_LEFT_SIDE=FEAT/PLANE,RECT,TRIANGLE
THEO/-65.158,15.888,14.142,-0.9543183,-0.298792,0.0000084
ACTL/-65.459,15.799,14.197,-0.9539852,-0.2998536,0.0003685
CONSTR/PLANE,BF,PNT13,PNT15,PNT16,PNT10,PNT11,PNT12,PNT14 ,,
LIN1_RIGHT =FEAT/LINE,RECT,UNBND
THEO/72.169,38.282,4,-0.2987947,-0.9543174,0
ACTL/72.513,38.194,4.043,-0.2997982,-0.9540026,0
CONSTR/LINE,BF,2D,PNT5,PNT4,PNT3,,
LIN2_LEFT =FEAT/LINE,RECT,UNBND
THEO/-71.401,35.829,4,0.2987873,-0.9543197,0
ACTL/-71.728,35.737,4.054,0.2998278,-0.9539934,0
CONSTR/LINE,BF,2D,PNT16,PNT15,PNT13,,
WORKPLANE/XPLUS
PLN9_CTR_X =FEAT/PLANE,RECT,TRIANGLE
THEO/0,0,0,1,0,0
ACTL/0,0,0,1,0,0
CONSTR/PLANE,ALIGN,WORKPLANE
WORKPLANE/ZPLUS
DATDEF/FEATURE=PLN2_BASE,DATUM=A
DATDEF/FEATURE=,DATUM=B
DATDEF/FEATURE=PLN9_CTR_X,DATUM=C
FCFSYM1 = SYMMETRY OF PLN3_RIGHT_SIDE,PLN4_LEFT_SIDE
FEATCTRLFRAME/SHOWPARAMS=YES,SHOWEXPANDED=YES
CADGRAPH=OFF REPORTGRAPH=OFF TEXT=OFF MULT=10.00 OUTPUT=BOTH UNITS=MM
DIMENSION/SYMMETRY,.2,C
NOTE/FCFSYM1
FEATURES/PLN3_RIGHT_SIDE,PLN4_LEFT_SIDE,,
PNT19_CC =FEAT/POINT,RECT
THEO/0,-192.221,4,0.2987873,-0.9543197,0
ACTL/0.011,-192.52,4.049,0.2998278,-0.9539934,0
CONSTR/POINT,INT,LIN2_LEFT,LIN1_RIGHT
DIM LOC1= LOCATION OF POINT PNT19_CC UNITS=MM ,$
X 0.000 0.050 0.050 0.011 0.011 0.000 -----#---
Y -192.221 0.250 0.250 -192.520 -0.299 0.049 <--------
END OF DIMENSION LOC1
DIM ANGL1= 3D ANGLE FROM PLANE PLN4_LEFT_SIDE TO YAXIS ,$
A -17.095 0.900 0.900 -17.449 -0.354 0.000 --#------
DIM ANGL3= 2D ANGLE FROM PLANE PLN3_RIGHT_SIDE TO YAXIS ,$
A 17.095 0.900 0.900 17.449 0.354 0.000 ------#--
DIM ANGL2= 3D ANGLE FROM PLANE PLN4_LEFT_SIDE TO PLANE PLN3_RIGHT_SIDE ,$
A 34.192 1.800 1.800 34.898 0.706 0.000 ------#--
Sample code bellow
ALIGNMENT/END
WORKPLANE/XPLUS
THEO/0,0,0,1,0,0
ACTL/0,0,0,1,0,0
WORKPLANE/ZPLUS
NOTE/FCFSYM1
