What do I need to change in the settings editor to make my report fit on an 8.5 by 11 sheet of paper. my true positions reports run off the edge of the page when the report prints. Seems like someone here mentioned a setting in the settings editor could be changed to fix this. If anyone knows what it is I would appreciate it . Thanks. I am running ver 3.7 MR3
Settings editor ?
There will be LOTS of things that do not fit on a line of print on an 8.5x11 sheet of paper and that will wrap around. There are NO settings in the settings editor to let you change any margins (nor can you do it from INSIDE Pcdmis). About the only things you can do are:
1) Change WHAT is being reported for the feature (MIN/MAX ~ +TOL ~ -TOL ~ MEAS ~ DEV, those kinds of things)
2) Change the FONT size, make it smaller
3) Change to V4+ (YUCK) and spend tons of time making custom report templates to make fit what you want to fit.sigpic
Originally posted by Matthew D. Hoedeman View Post1) Change WHAT is being reported for the feature (MIN/MAX ~ +TOL ~ -TOL ~ MEAS ~ DEV, those kinds of things)
by MOREPOWER2UHow do I turn off (disconnect) the setting editor? Somehow it has been activated and keeps loading at the end of my programs.
03-28-2013, 12:51 PM -
When I print out my reports they do not fit
on 8 1/2 x 11 paper. The right margin is cut off.
I am using the new style report not the "text...-
02-27-2009, 08:28 AM -
by Numbers GameRandom question here. While scrolling through the settings editor under the probcal section in search of a particular setting (which I never found) I...
04-05-2017, 04:28 PM -
by Randy Pis there a way to print out the setting in the settings editor. ver 3.5 mr2
04-25-2006, 02:15 PM -
by dennisgilpinCan anybody tell me where to turn on Autosave in the settings editor? PC-DMIS 2011MR1
Thanks-
07-26-2012, 08:24 PM -
