has anyone set up the manual tempature feature in pcdmis. if so what are the steps
temp compensation
by amer rehanIs it important to on the temp compensation when you are measuring a part where 10~15 micron accuracy is required. or it should be in all part programs....
05-22-2011, 01:07 PM -
by DeWain HodgeWhen using temp comp on the parts how long does the sensor need to be on the part before it reads the temp? If I use zero delay I've noticed I get temp...
10-06-2010, 11:08 AM -
by NMC_CMMGood Morning all,
I just had a question about using Temp Comp - do you have to have a material coefficient for your machine axes? If so,...-
08-19-2009, 09:08 AM -
by remotespenkeDuring measurement the workpiece temperature was 14.5 ° C
Now i want to report the results from the measurements with a reference temperature...-
Channel: PC-DMIS Portable
01-19-2016, 06:57 AM -
I've been looking for a MM4 guru but haven't had any success so I thought I'd try my luck with the PC-DMIS forum Gods.
My superiors want...-
04-13-2010, 10:18 AM -
