Good afternoon,
I am writing a program with a manual tip change. I start out with a 4x50mm tip and switch to a 2x20mm tip for checking small holes.
I inserted a new probe tip in the program and ran it through the graphic screen and the program runs fine.
But when I run the program on the machine the part where I change tips manually I get alarms and can not continue because PCDMIS thinks I caused an unexpected hit. Is there a way to run a program with a manual tip change for people that do not have the automatic tip changer?
I have a PH10M head with a TP200 probe and have all the tips on seperate magnetic attachments.
Thanks.
Thanks.
