TR_PBR01 No Probing within probe limit
  • TR_PBR01 No Probing within probe limit
    TR_PBR01 No Probing within probe limit.
    Global Image 3.7mr3
    Just started getting this friday in a program that we have been using for over a year.
    any ideas on why?
    B&S Global 544
    Using 3.7mr3
    Peace
    Greg
    Possibly your part is so far out of spec that it has exceeded the check distance limits ?
      Or, are you using an external saved alignment? If the part isn't in the same spot, it won't find it.
        No if I hit continue it will keep going, and in the end, the fartherst anything will be out is .005.
        issue is if I have a operator run it, you have to know if probe is in right spot to continue.
        B&S Global 544
        Using 3.7mr3
        Peace
        Greg
          No external aligment
          B&S Global 544
          Using 3.7mr3
          Peace
          Greg
            You're not out of travel are you?
              No,
              B&S Global 544
              Using 3.7mr3
              Peace
              Greg
                make sure all your moves are within limits after point got samething here part filling table corrected moves now ok
                3.7 MR4
                  Has someone adjusted the check distance value?
                    It is still set at 1 in the % box.
                    I should add that 80% of the time it don't even make a attempt to measure the hole, it just gets to the center position and stops.
                    I did just get it to make it all the way through once without stopping, I had to put some move points before 3 of the holes in the program. I'm letting it go through a second time and see if it makes it again.
                    B&S Global 544
                    Using 3.7mr3
                    Peace
                    Greg
                      made it a second time, going for 3 times in a row now, the program take around 21 mins to run.
                      B&S Global 544
                      Using 3.7mr3
                      Peace
                      Greg
                        didn't make it all the way through the 3rd time, this is on the same part without moving it.
                        B&S Global 544
                        Using 3.7mr3
                        Peace
                        Greg
