Intersecting Circles
  • Intersecting Circles
    Problem Solved Thanks To Matt.
    I need to find the point where two circles intersect (see attached). Any ideas?
    Well, you have to do CONSTRUCT ~ POINT, trhen YOU have to makr INTERSECTION. Then, you have 6 ways to get there, hopefully one of them will be right:
    CIR1 to CIR2
    CIR2 to CIR1
    REVERSED CIR2 to CIR1
    REVERSED CIR1 to CIR2
    REVERSED CIR2 to REVERSED CIR1
    REVERSED CIR1 to REVERSED CIR2
    I think one of these will get it.
      Thanks Matt,
      I tried that first, it wouldn't work. I got a "math failed" error. I just tried it again after reading your post with all the different combinations you listed. They all worked. I guess I gave up too easily.
      HI-JACK AWAY!
        Originally posted by Goodluck View Post
        Thanks Matt,
        HI-JACK AWAY!
        HI JILL!
          Try creating a point and select pierce not intersect. You may have to play with the order you select the circles.
            Thanks Matt,
            HI-JACK AWAY!
            HI JILL!
            Jack and Jill went up the hill.
            (somebody finish the Andrew Dice version)
              http://cmmprogrammer.19.forumer.com/...hp?p=4224#4224
              Posted it here for ya
                Easiest way is to use this: http://www.selectsmart.com/darex/cir_cir.html
