I am reverse Engineering my companies thermoform molds that do not have any documentation of what they are. I am scanning with a SP25 probe. When it scans parallel with a cavity wall it starts to search for the edge which is ok but it takes odd points during this time. Any sugestions on how to keep it from taking points while it is searching? Or any other help on reverse engineering? Brown and Sharpe suggested slowing the scan speed down but that didn't seem to help.
Reverse Engineering with SP25 probe
If it is going over a sharp corner, the only way I have found to eliminate the searching is to break the scan up so that each side of the corner is a different scan (using a TTP).
Is the SP25 a scanning probe or are you going to have issues with the probe comp being a little off since Pcdmis will only comp in a 2-D plane for each scan line? If it is a probe made for scanning (ie reads the DEFLECTION and deflection DIRECTION of the probe as well as the contact) than you should be alright. If it is NOT, then you may have slightly bad data due to the fact that Pcdmis will ONLY comp for the probe in 2-D, the cut plane of the scan line, when using vector points. This is where surface points with sample hits come into play. Of course, if it IS a scanning probe, then you can just ignore this information (but the REST of you, pay attention!).
To anyone that ever has the same problem reverse engineering I finally got an answer. Using the SP25 scanning probe I had to use a linear scan and pattern it instead of using a patch scan. The two are similar but comp the probe differently. The probe comp in the patch scan could not handle the complex shapes of our thermoform molds.
If you are using 3.7 mr3 there is a check box for "CAD COMP". If you check that box, it uses a different algorithm than normal. I will probably screw up the definition of so be patient. What CAD COMP does is utilize the algorithm from QUINDOS as it has a better method for defining 3D topograghy. I know it doesn't really apply for this situation, but I thought I 'd share.sigpic
by enviroHi All, I am trying to scan a blade profile to export as IGES to create a reversed engineerd part.
I was told somewhere up the line that PATCH...-
02-25-2009, 02:16 PM -
I need to reverse engineering a rectangular area at X=.1 by Z=.1 hard increments for the whole area. Anyone know the best scan for this?
03-27-2008, 06:23 AM -
by mange34I have a problem with scaning compared to a 3D part .
I want to scan the light blue surface as you can see on the pix i have instert....-
09-13-2007, 08:44 AM -
by MikegMy company is looking at buying another CMM. We currently have a global 555 using PC-DMIS 2015 with a touch probe, they are going to by a similar CMM...
03-08-2017, 08:31 AM -
by MrCommentIm using an SP600M and v4.2 MR1
For the past month now I've been having trouble with scanning surfaces on the sides of the probe tip. Seemlingly...-
05-08-2008, 10:40 AM -
