Something strange is happening.When I create an offline program,and run it off line,everything looks great.When I close the file and reopen it,I noticed that the theoretical values have changed in the vectors i,j,k only.The x,y,z values remain the same.The points used in the alignment(an "iteratve" then a "manual" alignment) are good,meaning the theoreticals,actuals,target points all match.But in the points after the alignment,the theoreticals have changed.The x,y,z, are the same but the vectors i,j,k have changed which causes the hits to be off.This is all happens when i close and reopen the program.
