Datum Definition
  • Datum Definition
    Is this important?
    I would imagine so, considering all the parts have datums, but what is the difference from, say, setting a point as Datum A and dimensioning a feature to Datum A, and setting a point and dimensioning a feature to said point?
    If you use XactMeasure, you need to define datums. If you don't use XactMeasure, you can ignore datum definition.
      I don't know! I don't know what that is!
      If you couldn't tell I didn't take much class, except a 1 day crash course and then someone came to calibrate where I learned some things.
      I use the dimension toolbar if that helps...
        As far as I understood it, I can take a point on 1 end of a part, and take a point on the other end. If I want to find out the distance between the two points, it shouldn't matter that 1 is a datum and 1 is not. It should matter that I want the distance between the two points. But if I take a point in the middle of a round flat feature, and another at the top of a father away round flat feature, if I want the distance in Y I would ask for the distance in Y, and it would give me the distance in Y, and setting one or the other or both to a datum wouldn't make a difference because Y is still Y and the points haven't moved.
        Is this correct?
          It sounds like you aren't talking about Datum Definition at all. That's a specific thing where you are using XactMeasure and when making a Position dimension, you define the datum for use in building your DRF to the Feature Control Frame.
          Distances can be 2D or 3D, and can be parallel or perpendicular to an axis or a feature. If you have a datum feature to another feature, the datum feature should be picked 2nd. If you have a line or plane, the vector of the distance can be related to the vector of the feature. Point to point, you need to specify a direction, either to an axis or 3D. It all depends on the feature, the specific callout, the print, etc.
          A 3D distance is measured from centroid to centroid, regardless of orientation. 2D distance is workplane and feature dependent. You must be in the right workplane and specify the right measurement orientation.
            If you are measuring a point to a point, you don't need to set the Datum Definitions in PC-DMIS. As Vinni said, you would need to set them if you are using Xact Measure and dimensioning a GD&T callout.
            Make sure your alignment are rock solid as well. You could be dimensioning something incorrectly if it is not.
              On a SINGLE point, to another SINGLE point, it shouldn’t matter. But if it’s between two planes, or two cylinders, it certainly could. It all depends on the size, vector and distance between the features in question.
                @OP, when you ask for true position, does it look like the right or left window?
                • QS920
                  QS920 commented
                  It depends on what you have your dimension reporting set for... if it's set for legacy it will be the window on the left, if it is set for Xact measure it will look like the window on the right.
                • RandomJerk
                  RandomJerk commented
                  My bad, I should have put @OP in there.
                • InspectorJester
                  InspectorJester commented
                  The left! I have seen the other window however
                So the general consensus is I should set features as datums, if anything for posterity's sake, considering I take more than a single point to define a couple features.
                Works for me!
                So a datum definition question in and of itself:
                I have a rotary table that clamps down cylindrical parts with a flat face. This face is usually datum B, my Y origin. Datum A is the OD of the cylindrical part itself, which I level to. Datum C is undefined, so I set up points and lines to generate a rotation vector.
                Would I be better off defining these features as Datums? Almost all measurements use at least one of these features in its' construction.
                Also along these lines, I'm having an issue with Datum B...
                I am uneasy with the rotary table and subsequent calibration; I'm not seasoned in PC-DMIS, rotary tables, machining, or anything related to any of them in any way. So I do not trust it's accuracy.
                When it rotates to 45°, I am pretty sure it's actually 45°. But I'm not sure how tilted the part is in the rotary table, if that makes sense.
                Say I want to generate a plane as Datum B. To do that I would want to rotate to each of the relevant vectors (every 30° or 45° typically) and take a point on the face, then construct a plane out of these points.
                How can I be sure that the Y axis is level? I would imagine if the part is tilted sideways a little in the rotab, a point on the left side would be farther away than a point on the right, for example.
                Would I be better off trying it and reporting the flatness of the plane?
                Is using a single point for a datum such as a Y axis insufficient?
                Is using a singe point at each rotation and constructing a plane going to be insufficient due to part sway/tilt from the chuck?
                Is there a way to test this?
                Is this better asked in a different forum?
                Who knows?
                • VinniUSMC
                  VinniUSMC commented
                  If you use legacy, (as you answered the "left" picture above" then defining datums is pointless, as you won't use them. If you are aligning to your datums and using legacy dimensions, then you are already "defining" the DRF (Datum Definition is a particular thing in PC-DMIS, it has a meaning, that is not how you are using it).
                  I'm not going to answer rotary table questions, since I never use one.
                • RandomJerk
                  Based on the answer to my question above, you do not need to use the PC-DMIS function "Datum Definition". However, when you say you've "seen" the other window, what do you mean? I'm asking because if you go to Insert...Dimension...Location, it looks similar to the left window, but if you went to Insert...Dimension...True position and it looks like the one on the right, you do have Xact measure turned on.
                  If you go to Insert...Dimension, and look at the very bottom of that sub menu, is the a check box next to "Use legacy dimensions"
                  You do still need to do a proper alignment, however. As an aside, "Datum Definition" does NOT create an alignment, it only defines what the feature the datum letter is.
                Thanks! Your help is greatly appreciated. I didn't want my measurements to be made inaccurate because of a simple switch!
                And I will figure out the rotary table question and get back to you, while I've got time to play on the CMM.
                As an aside: The alignment is proper, Level Rotate Origin syntax, all 6 axes defined, the trihedron unmoving in the GDW...
                • JuanGauthInd
                  Parallelism
                  by JuanGauthInd
                  When inserting the parallelism dimension, what exactly does pc-dmis give you as an output? I have two planes, with different z-coordinates, and I'm trying...
                  03-12-2008, 09:16 PM
                • ClayOgre
                  GD&T question
                  by ClayOgre
                  I have come across a number of prints where the datums are unmachined cast surfaces, and in a couple of cases, the datum was a single point on a cast...
                  02-08-2008, 08:59 AM
                • IZAKK
                  Compound Datum
                  by IZAKK
                  Hi All,
                  I am hoping that someone here will help me with some information. I am looking for the definition of a compound datum or the rules...
                  04-10-2009, 02:35 PM
                • Potato head
                  Define a Datum
                  by Potato head
                  Do datums have a tolerance? If the primary datum has say .010 deviation along its surface, and my cmm picks up both the high and the low points of that...
                  02-09-2007, 03:37 PM
                • mhwoodlief
                  Checking Parallelism
                  by mhwoodlief
                  I want to check parallelism of 2 lines, line1 and line2. PC-Dmis requires me to create Datums before I can check the parallelism. On our "old machine,"...
                  10-27-2008, 12:05 PM
