no z-axis dimensions
  • no z-axis dimensions
    Hoping for a little help with this.
    I am getting good hit data with my DEA Gamma, PH10M, and PC-DMIS v3.2, but when I try to dimension parallel to the z-axis, the dimension always comes out 0. Checking the data reveals the points are clearly not at the same z value. I got z-dimensions once, but found that I had lost x! so I changed the alignment back. Any ideas?
    Do you have it set to project into current work plane? Not sure where the setting is, but there is one someplace and that is what it would do to you.
      Are you doing distance dimension by any chance? You may need to adjust your workplane if so.
        Thanks
        That seems to work thanks. Is there any reason other than the need for clearplanes that PC-DMIS won't do all 3 dimensions without switching workplanes? Seems unnecessary to me.
          Pcdmis does all 3 axis without any problems at all. Check in the list of the F5 setup and make sure that MOVE FEATURE TO REFERENCE PLANE is not marked. If it IS marked, then the axis that matches your workplane will ALWAYS be zero. Distances, however, ARE dependant on HOW YOU LOOK AT THE PART. IF you look at it from the 'right', then to get distances that match that point of view, then you need to use that point of view, ie workplane. for XYZ values, just make sure that MOVE....PLANE is unmarked and you will get the XYZ values of the touch, no matter what workplane (view) you are using.
            I think he is doing dimension distance. Not dimension location. He is probably saying "all 3 dimensions" because of the radio button option for axis selection in regards to paralell or perpendicular.
              Ah, yat another good reason for posting code or pictures of the issue as that everyone can be on the same page.
                Code would have solved it lickety split. He'll catch on to that one. Could have been worse, justincredible could have lambasted him for not being born with PCDMIS experience. Where has that guy been lately?
                  We can only hope that he got a Booger-boy-type eviction from the board.
                    But they let Booger boy come back (that is good). I think it is more like the Winston-type self-banishment that took place right after this board started.
