Say you have two parts that are quite similar and use the same basic alignments. Say you were to pull up the wrong program for the wrong part and pick up your manual alignment and then start DCC and notice that your dimensions are checking out and realize you have the wrong program pulled up. Is there any way that you could pull up the correct program and save some time by telling it to use the manual alignment from the previous program?
alignment question
I am looking for some help on how to create and run using an external alignment, I have tried once before with what can only be described as disastrous...
11-24-2016, 11:22 AM -
by Ben1989Hi guys.
Where I work we currently operate 20 CMMs. Certain programs in the factory are validated to run on several CMMs. When the operators...-
03-25-2015, 10:25 AM -
by AAP_CMMI am still a little wet behind the ear when it comes to programming our CMM machines and our previous programmer is no longer here. We measure aluminum...
02-13-2017, 10:54 AM -
by AuRulesJust a question about branch looping around an alignment. Does PCDMIS retain the new alignment when it loops back around and improve upon it? It appears...
05-14-2008, 07:55 AM -
by B. Jacobs
OK guys, Here is one of those stupid questions.
I haven't had to do this yet , but wouldn't you know it, I need to do it now. I have read about...-
04-27-2006, 10:50 AM -
