I am trying to run PCDmis 3.7 in offline mode on my home PC. I have brought the portlock home with me off one of our machines and installed 3.7mr3. I can't get it to run. Here are a couple messages I'm getting......Any ideas?
offline
I Tried to read the errors but the pics were to small. Did you run the portlock program? It Should be P portlock#_V#.pwd. This is a file B&S sends with the SMA you install and then change to an EXE extension and run.Tolerance challenged ... Living in the world of unseen lines.
well that's no good! What if I copies all the necessary files and brought them home too??
Sorry have not seen either message. I have had problems with updates that required me to copy and paste a dozen or so files from the old program into the new one.
Is this the first time you have tried to do this?Tolerance challenged ... Living in the world of unseen lines.
Copying the files won't help there is a way for the program to see the machine motherboard and recognize it. Others have complained about this. Try doing a search on offline and I think you will find more infoTolerance challenged ... Living in the world of unseen lines.
Unless you have an OFFLINE portlock, you MUST be attached to a working, running machine to use either ONLINE of OFFLINE (which without the offline purchace is really only a background editor, not an offline seat).sigpic
I have an offline portlock hasp key which I share successfully between two computers. One is the desktop I use at work, the other is a notebook I use when traveling to other worksites. In both cases when installing PCDMIS, I inserted the same offline portlock when instructed to do so during the installation. Before starting PCDMIS on either computer I make sure the key in plugged in and light on. I'm using 3.7 MR3 on both with none of the problems you have.
After installing the software with the key inplace did you start PCDMIS after the installation to finish the registery entries?
Also on your home computer are you using the "administrator account" or an account with administrator privileges?
You need admin privs in order to enable the PCDMIS installation process to update the registry.
I think my questions have been answered. I obviously need to by an offline seat. Thanks for the replies.
by mikoldWe have just absorbed an offline usb portlock from another division. Can I interchange that portlock between different computers say a laptop and a d...
05-20-2008, 02:03 PM -
by granpagusIs the port lock included with the offline license?
Or is it more $$$ ?-
11-14-2008, 08:34 PM -
by BeckyKOur air dryer caught fire and the air was shut off to our lab. We have an offline seat but could not get to it because the machine could not home. (What...
09-11-2018, 03:20 PM -
by bockerickjust installed pc dmis on my computer at work (not the one used for pcdims) and i cant seem to figure out to work in it offline.
12-14-2012, 09:55 AM -
by DeWain HodgeI'm trying to start programing offline. The company I work for only has the one CMM (Xcel 7.6.5). Therefore we have one portlock. I have remove the...
12-13-2007, 04:11 PM -
