Scanning Report
  • Scanning Report
    I'm trying to create a scanning report that one of our engineers is looking for. I'm attaching a picture but what they want to see is an outline of the low tolerance of a profile, an outline of the max outline of a profile and an outline of where the part actually measured on that profile. They also want arrows like the ones displayed in the picture I'm attaching that show a direction that the measured surface is out of tolerance in areas that are out of spec. I know that this is being displayed in the graphics display window I'm just not sure how to get the arrows. Any advice?
    Thanks
    You have to dimension the profile, then select "on" on display graphic in the dimension command.
      ^^this^^
      in addition, if using XactMeas, you can go to the advanced settings (second tab or the like) and set the graphical to form, form + location, size multiplier etc., In analysis view, more options like show/hide tolerance band, percent of arrows, etc...
        In the analysis view window select "options" then "dimension options", after that select "Show max/min deviations" (see attached). Hope this is what you are trying to achieve in the report view?
        Global Advantage 12-15-10 PH10MQ SP600M V4.2MR3 CAD++
          Just in case the OP doesn't know: the first step is to construct a feature set from the measured points. Apply the profile tolerance to the set.
