So I am building a fixture using the R&R components. One of the components is an adjustable jack stand AJ-50-20. Is there a way to change the length of the jack stand such that it looks correct when used in conjunction with other components? See attachment for example.
Quick Fixture question...
I get it "close enough" by creating generic lines to then click and drag the edges of the fixtures to it, you have to zoom in all the way to get the best results. Best solution I could find.
Or if it's something extremely critical you may have to reverse engineer the components and draw up a model in your favorite CAD application.PcDmis 2015.1 SP10 CAD++
Global 7-10-7 DC800S
That's the route I have taken. I have a huge generic "setup" that I start with in solidworks. I import my part, move and mate the standoffs / clamps I need and then delete the rest. Export and start programming offline. This make is so much easier to program as there are no nasty suprises at prove out with an unexpected clamp in the way or what ever it may be. Makes a setup sheet for the CMM fixture build so much easier with a screen shot on it as well. Operators run all their own parts here. Going to the assembly method has been a huge improvement here.
- 1 like
Using cad software is far easier then Quick Fixture. I use Solidworks to create a complete assembly of the Part, Fixture and CMM Fixture plate. In Solidworks I have created a library (Solidworks CMM Fixtures) in the Design Library. This Library is link to a folder on the server so I can access this file from any pc using Solidworks. Another affordable option is Fusion 360 that I have also created the same Fixture components file in the Data Panel (CMM Fixtures). Also, R&R Fixtures do have a software integrated with a CAD software from IronCad called Fixture Builder. Not sure what the cost of Fixture Builder is anymore. I haven't used this since 2009.
- 1 like
by DmisDaveI haven’t had much luck in using quick fixture mode since version 2013. Unless my fixture setup is simple X,Y moves I have to load my model and fixtures...
03-24-2017, 11:35 AM -
by afennerSo I build this nice fixture to import into pc-dmis, I get it all done. Import it into pc-dmis, and I can barely see it.
I exported it...-
02-11-2008, 11:49 AM -
by MansukhI do not know how to synchronize fixture with part model. I tried to rest the model on quick fixture magnets but it does not work. I will appreciate for...
11-12-2010, 10:31 AM -
by jjewellUsing 3.7MR3. Trying to use the quick fixture option. I can get stuff in, position it, but can't seem to figure out how to rotate the orientation of the...
08-24-2010, 07:26 AM -
by scharschHi,
I'm getting a little ahead of myself but I plan on making a fixture up to hold my part/s. I plan on using flow control to measure multiple...-
04-07-2008, 03:32 PM -
