I need to know how to make a move point programming offline with a catia model. It will not let me click off the part and I don't want clearplanes.... Please help a fellow beer drinker.....
Moves
Originally posted by AuRules View PostI need to know how to make a move point programming offline with a catia model. It will not let me click off the part and I don't want clearplanes.... Please help a fellow beer drinker.....
If you prefer go to pull down menu INSERT/MOVE/MOVE POINT.sigpicIt's corona time!
Originally posted by craiger_ny View Postctrl + m does not work in offline?Last edited by AuRules; 03-09-2007, 12:56 PM.sigpic
Moves
I'm not understanding the (3) views method AuRules, can you please elaborate? When programming offline, you cannot move probe away from part and see it in space.The probe disapears after taking hit on part, correct?How would I add move points to navagate around the part when the part is in the aircraft coordinate system and the trihedrant is not perpindicular to any surfaces? I am wanting to add move points after creating an "iterative" alignment to get around part to create a manual alignment to bring part into the local coordinate system.
I use move increment a lot to clear the part or when measuring using auto features I use the distance move set to both or whatever fits the need.
Control + M does work in offline at least it does in 3.7MR3.Xcel & MicroVal Pfx & Global 37mr4 thru 2012mr1sp3
Contura Calypso 5.4
Originally posted by cmmcaliguy View PostI'm not understanding the (3) views method AuRules, can you please elaborate? When programming offline, you cannot move probe away from part and see it in space.The probe disapears after taking hit on part, correct?
Create you views, make them solid, drag your tip in each view and hit ctrl+m.
I tried it and it works so thank all for your input.....and far as an iterate alignment it should work because you move x-y-z cordinates come from alignment no matter where it is.Last edited by AuRules; 07-07-2008, 02:03 PM.sigpic
by DarrollHow do I set up move points while programming offline?
11-28-2014, 07:11 PM -
by WingmanAll,
I am doing offline proramming from model and have need to insert move points within a feature. Currently I have been doing features like...-
10-31-2007, 01:40 PM -
Good morning folks. Time for Question of the day. I have gotten my books and have pieced together basic CAD programming from what I know from my Calypso...
08-20-2014, 09:06 AM -
by DarrollHow do you set up move points on PCDMIS? I've used Romer and non DCC units before. Thanks for any help.
Sent from my HTC6500LVW using Ta...-
08-31-2015, 04:51 PM -
by kcassadayIf I'm programming from a CAD model and need to put in "Move Points", how is this done? Thanks.
10-26-2017, 10:24 AM -
