Need to ask, is these proper steps correct.....
1) When I download my catia model the PH10M probe head does not match my model cordinates I can correct this 1st by F5-part setup-change my cad axis to match my machine axis and then anymore fine tuning it will be with adjust button. Is this just a visual only......
2) Now I do a manual iterate alignment (6 points if not more)....
3)Turn DCC on remeasure my points and do a iterate alignment....
4) Now all my moves commands come of the part alignment which in reality still not set to the true machine cordinates so I use before and after move command in the auto features to match my vector directions.
5) Is these step correct because I don't use iterate alignments much yet I just wanted to make sure this is the correct procedure and please add any positive comments to this.
Thanks, also I need a cmm program to generate the numbers for the mega millions that right now at a estimated 370 million.....
