Iterative Alignment Question
  • Iterative Alignment Question
    CAD is CAR Body position. I will be using iterative alignment for set up. I will probably not use the datum s for the initial alignment then make another alignment using the datum features. 3 datum targets on different planes for level ( Datum A ),
    A diameter and a point for rotate ( Datum s B and C ) and Datum B diameter for origin.
    My question is, for measurements to Datum A, B, C that follow, did the iterative alignment use the 3 datum A points to assist in setting the origin for that axis ( X axis )? Or did it only use X axis information from coming from the datum B diameter which I defined as "origin" in the iterative alignment?
    I can understand that orientation to CAR Body is correct, what about location?
    If your Datum A targets are 1,0,0 (or -1,0,0) or thereabouts, then yes, they are what set the X axis origin. The level axis also sets the origin (offset to keep car position) for that axis.
    Rotate and Origin axes seem to know the difference between plane/line/point and plane/circle/circle when setting origin.
    • bpierce
      bpierce commented
      Thanks for your word on it.
      I will proceed as planned with no further adjustment to the alignment.
  • dea3cmm
    iterative alignment
    by dea3cmm
    hello everyone.
    question on iterative alignment.
    can i take 3 points to level, two datum cirlces (which is on the some plane surface...
    03-17-2006, 12:28 PM
  • Clay_Man
    Iterative Alignment
    by Clay_Man
    PDDMIS 4.1 CAD++
    Hi all, I am fairly new to iterative alignments, I have a part with datum -A- a plane datum -B- a stud and datum -C- a...
    01-29-2007, 11:21 AM
  • dtmtim
    Alignment Help
    by dtmtim
    Good morning, the datums defined on the customer print are a bit confusing and may not be defined correctly (big surprise).
    Datum A =...
    02-01-2007, 09:00 AM
  • Tested
    Alignment question
    by Tested
    I have a part print that has got me scratching my head. I made a drawing of the area in question “see attachment”.
    What I have is DATUM –A-...
    01-26-2007, 10:28 AM
  • Bob Pierce
    Alignment help
    by Bob Pierce
    I have never had to make an alignment such as the one in the attachment.
    Datum C is to be added and will be the axis of the 10MM screw hole on...
    03-05-2009, 02:31 PM
