CummingsDeisel,
Sorry about the hi-jack in process on the linked thread. The answer to your question is to loosen tip #1, the one facing you in your photo, or the one pointing down at A0B0, this will allow the portion of the star probe holding the other 4 tips to rotate. This is a bit touchy to retighten and keep them exactly square, but with some trial and error it can be done. HTH
Looks like the same problem I used to have when my former employer would buy the cheap star probe knuckles that are fixed and don't rotate around tip one.
Our solution?
We used paper washers between the tip extension to allow use to get the probe to align to the right direction. Basically cut a small piece of paper (square, circle, what ever) and poke a small hole big enough for the extension thread between the TP2 and the shank.
Do I recommend doing this? No, it sucks. Loses up to easy, in my opinion it's not accurate too.
Spend the cash and get one of the knuckles that rotates around tip 1 if this sounds like your problem.
Did this post solve your problem? Let everyone know and help future users out!
I need to use this CMM , And PH_6 head is only Moving in A0B0(use for floor Inspection)and they want to used for small part with holes in all direction...
Up until recently, I haven't had to mess with star probes, but I am having to write some programs for this really huge (literally one ton) engine block,...
